We built desktop workstation power, performance and expandability into a device designed for the road. Made for mobile creative and design professionals with the most demanding projects, where compromise is simply not an option.
Discover gravity defying performance
Made for the most demanding workloads, the HP ZBook 15 is used by NASA to help push the boundaries of science and discovery on the International Space Station. Imagine what it could do for you. -
Extreme power
Designed for your most demanding workloads, our HP ZBook 15 is engineered with the latest Intel Xeon processors, NVIDIA Quadro or AMD Radeon Pro graphics, up to 3 TB of storage and dual Thunderbolt 3 ports. -
No compromise reliability
Confidently take on your workday with our durable & reliable HP ZBook 15. With a 3-year onsite limited warranty, 120,000 hours of testing, and 30 years of HP Z DNA this is where the fusion of innovation, performance & reliability meet.
- HP ZBook 15 G4 Mobile Workstation - 15.6" - Intel Xeon E3-1505MV6 - 32 GB RAM - 512 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Xeon E3-1505MV6 / 3 GHz (4 GHz) / 8 MB Cache
- Memory
- 32 GB DDR4 (2 x 16 GB)
- Storage
- 512 GB SSD - HP Z Turbo Drive G2, NVMe, MLC
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD - 141 ppi
- Graphics
- NVIDIA Quadro M2200 / Intel HD Graphics P630
- Video Memory
- 4 GB GDDR5 SDRAM
- Input Device
- Keyboard, touchpad, pointing stick
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 9-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 38.6 cm x 26.4 cm x 2.6 cm
- 2.6 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM236 Express
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 32 GB (2 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM - ECC
- Speed
- 2400 MHz / PC4-19200
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 2
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe - HP Z Turbo Drive G2, NVM Express (NVMe), multi-level cell (MLC)
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Pixel Density (ppi)
- 141
- Image Brightness
- 300 cd/m²
- Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Numeric Keypad
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Remote Management Protocol
- SNMP 2
- Miracast, Wake-on-LAN (WOL), dual stream (2x2)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 9-cell lithium polymer
- Capacity
- 90 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 150 Watt
Connections & Expansion
- 2 x USB-C (supports Thunderbolt 3, DisplayPort Alt Mode) , 3 x USB 3.0 , Headphone/microphone combo jack , HDMI , VGA , LAN
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC UHS-II Card)
Software
- Software Included
- Skype, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, HP Velocity, HP JumpStart, HP Workwise, HP Noise Cancellation, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP JetAdvantage
- Security
- HP 3D DriveGuard, HP DuraKeys, HP SpareKey, soft-touch surface, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES, Common Criteria EAL4+, low halogen
- Localization
- 2.6 kg
Sustainability Information
- ENERGY STAR Certified
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack | In Stock | £13.44 |
HP Dual Head Keyed Cable Lock | In Stock | £43.00 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site | In Stock | £94.04 |
Other bundles (8)
HPE HDMI to DVI Adapter | In Stock | £9.89 |
HP USB Travel Mouse | In Stock | £10.03 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP Z38c 37.5" 3840x1600 5ms HDMI DisplayPort USB-C Curved IPS LED Monitor | In Stock | £1,036.31 |
HP Premium Wireless Mouse | In Stock | £38.00 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £47.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £150.00 |
