HP ZBook 15 G4 Core i7-7700 16GB 256GB SSD 15.6" Windows 10 Pro
Quicklinx: DPZBWS00 Mfr#: 1RQ74ET#ABU
Display Size: 15.6in
Processor Model: I7-7700HQ
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 256GB
  • Core i7
  • IEEE 802.11n
£2,022.66 ex VAT
£2,427.19 inc VAT
We built desktop workstation power, performance and expandability into a device designed for the road. Made for mobile creative and design professionals with the most demanding projects, where compromise is simply not an option.
  • Discover gravity defying performance
    Made for the most demanding workloads, the HP ZBook 15 is used by NASA to help push the boundaries of science and discovery on the International Space Station. Imagine what it could do for you.
  • Extreme power
    Designed for your most demanding workloads, our HP ZBook 15 is engineered with the latest Intel Xeon processors, NVIDIA Quadro or AMD Radeon Pro graphics, up to 3 TB of storage and dual Thunderbolt 3 ports.
  • No compromise reliability
    Confidently take on your workday with our durable & reliable HP ZBook 15. With a 3-year onsite limited warranty, 120,000 hours of testing, and 30 years of HP Z DNA this is where the fusion of innovation, performance & reliability meet.
HP ZBook 15 G4 Mobile Workstation - 15.6" - Core i7 7700HQ - 16 GB RAM - 256 GB SSD - QWERTY UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (7th Gen) 7700HQ / 2.8 GHz (3.8 GHz) / 6 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
256 GB - M.2 2280 SSD HP Turbo Drive
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro M1200 / Intel HD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
Input Device
Pointing stick
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
9-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
38.6 cm x 26.4 cm x 2.6 cm
2.6 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Mobile Intel CM238 Express
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (2 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM - non-ECC
Speed
2400 MHz / PC4-19200 - 2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
2
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - HP Turbo Drive
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
300 cd/m²
Full HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Sound
Stereo speakers, dual array microphone
Audio Features
Bang & Olufsen Audio
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Keyboard Layout
QWERTY UK
Numeric Keypad
Volume control, spill-resistant, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Remote Management Protocol
SNMP 2
Miracast, Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
9-cell lithium polymer
90 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
LAN , VGA , USB 3.0 (charging) , HDMI , 2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort , Headphone/microphone combo jack , 2 x USB 3.0
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Security
HP 3D DriveGuard, HP DuraKeys, HP SpareKey, soft-touch surface, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, WEEE
Localization
2.6 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP ZBook 15 G4 Core i7-7700 16GB 256GB SSD 15.6 Bundle deal on HP ZBook 15 G4 Core i7-7700 16GB 256GB SSD 15.6" Windows 10 Pro
£2,210.30
saving £8.33
£2,122.42
Optical Storage: None
Graphics: NVIDIA Quadro M1200 / Intel HD Graphics 630
Hard Drive Type: SSD
Type: Laptop
Brand: HP
Price Range Ex VAT: 1500+
