Work almost anywhere on the HP ZBook 15 mobile workstation. Its mobility and robust configurability, create a powerful mix of style, features, and portability in a thin, light, 39,6 cm (15.6") diagonal form factor.
Impress and perform
HP's most popular mobile workstation has been redesigned, inside and out. Now 27% thinner and 15% lighter than the previous generation, it offers 100% more wow-it's designed to impress and perform. -
Create your ideal workstation
Configure the HP ZBook 15 with an Intel Xeon processor, 64 GB ECC memory, mid-range NVIDIA Quadro or AMD FirePro professional graphics, dual HP Z Turbo Drives, 3 TB of total storage, dual Thunderbolt 3, and an optional HP DreamColor UHD display. -
Defined by HP Z DNA
Work confidently with HP mobile workstations designed around 30 years of HP Z DNA with extensive ISV certification. It's reliable, designed to pass MIL-STD 810G testing, and endure 120K hours in HP's Total Test Process.
- HP ZBook 15 G3 Mobile Workstation - 15.6" - Core i7 6700HQ - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Processor
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz (3.5 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (2 x 4 GB)
- Storage
- 256 GB SSD HP Z Turbo Drive G2
- Optical Drive
- No optical drive
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro M1000M / Intel HD Graphics 530
- Video Memory
- 2 GB GDDR5 SDRAM
- Input Device
- Pointing stick
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 9-cell
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
- Space Silver
- 38.6 cm x 26.4 cm x 2.6 cm
- 2.59 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM236 Express
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (2 x 4 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 2
Storage
- Main Storage
- 256 GB SSD - (M.2) PCIe - HP Z Turbo Drive G2
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, Panel Self Refresh (PSR)
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 2 GB GDDR5 SDRAM
- Video System Features
- NVIDIA Optimus, Shader Model 5.0
- Camera
- Yes - 1280 x 720
- Camera Features
- 720p HD movie recording, low light enhancement
- Sound
- Stereo speakers, two microphones
- Codec
- CX7501
- High Definition Audio, DTS Studio Sound, DTS SOUND+
- Audio Features
- Bang & Olufsen Audio
Input
- Keyboard, touchpad, pointing stick
- Keyboard Layout
- UK
- Numeric Keypad
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Remote Management Protocol
- SNMP 2
- Wake-on-LAN (WOL)
- IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
- Technology
- 9-cell lithium polymer
- Capacity
- 90 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 150 Watt, 19.5 V
Connections & Expansion
- VGA , HDMI , 2 x Thunderbolt 3 , Headphone/microphone combo jack , LAN , 3 x USB 3.0
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- Drivers & Utilities, Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Setup, HP Hotkey Support, PDF Complete Corporate Edition, HP Performance Advisor, Microsoft Internet Explorer 9.0, CyberLink YouCam BE, HP Wallpaper, HP Spare Key, Password Manager, Microsoft Internet Explorer 10, HP Peak Power Manager (free download), HP Client Security, Device Access Manager with Just In Time Authentication, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP File Sanitizer, Box.net 50GB storage, HP Trust Circles Standard, Privacy Manager (free download), HP Disk Sanitizer, HP Ceement, HP Manageability, HP Wireless Button Driver, HP Validity Fingerprint Driver, HP Software Setup, HP Client Security Manager, HP 3D DriveGuard
- Space Silver
- Case Material
- Aluminum, magnesium alloy
- Security
- HP DuraKeys, One-Step Logon, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port, Pre-boot Authentication
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, WEEE, A-Tick, ICES, Common Criteria EAL4+, KC
- Localization
- 2.59 kg
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Software applications
Bundle includes:
Microsoft Office Home & Business 2019 Box Pack (Medialess, 1 PC, One Time Purchase) worth £191.34 | in stock |
£1,430.25
saving £8.33
saving £8.33
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£1,346.41
