HP ZBook 14u G6 Intel Core i7-8565U 16GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: FDRGWS00 Mfr#: 6TP84ET#ABU
Display Size: 14in
Processor Model: I7-8565U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 256GB
  • Core i7
  • IEEE 802.11n
13 in stock
£975.54 ex VAT
£1,170.64 inc VAT
Our thinnest, lightest ZBook ever provides true portability for people who push their typical office computer past the breaking point. Whether in the office or out in the field, you'll get high-speed, reliable performance.
  • Designed for road warriors
    Weighing in at less than 1.58, you get high performance without the weight. And with the latest connectivity and security features, you don't have to worry about losing your connection or compromising your valuable data when you're on the move.
  • Power user performance
    Say goodbye to slowdowns. Power through your projects and cut through your workload with 8th Gen Intel processors and 50% faster graphics than our last gen. Open large files and run multiple apps for unrestricted multitasking and productivity.
  • Software certified
    Work confidently knowing your laptop is certified to tackle the most demanding applications. We've partnered with leading professional software providers to ensure your ZBook is optimized for peak performance.
HP ZBook 14u G6 Mobile Workstation - 14" - Core i7 8565U - 16 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8565U / 1.8 GHz (4.6 GHz) / 8 MB Cache /
16 GB DDR4 (1 x 16 GB)
Storage
256 GB SSD TCG Opal Encryption 2, NVMe, TLC
Optical Drive
No optical drive
Display
14" WLED 1920 x 1080 / Full HD
Graphics
AMD Radeon Pro WX 3200 / Intel UHD Graphics 620
Video Memory
4 GB GDDR5 SDRAM
Input Device
Pointing stick, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, NFC, Bluetooth 5.0, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
32.6 cm x 23.43 cm x 1.79 cm
1.48 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.6 GHz
Number of Cores
Quad-Core
Cache
L3 - 8 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (1 x 16 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
3
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - TCG Opal Encryption 2, NVM Express (NVMe), triple-level cell (TLC)
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
250 cd/m²
45% NTSC colour gamut, Full HD anti-glare
Keyboard Name
HP Collaboration
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Camera
Yes - HD
Video Resolutions
720p
Camera Features
Windows Hello, HP Privacy HD
Sound
Stereo speakers, dual array microphone
Audio Features
Bang & Olufsen Audio
Input
Keyboard, pointing stick, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch clickpad, gesture function
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Dual stream (2x2)
IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
50 Wh
AC Adapter
Input
Output
65 Watt
Connections & Expansion
USB 3.1 (charging) , Headphone/microphone combo jack , LAN , Dock , USB-C 3.1/Thunderbolt 3 , HDMI , USB 3.1
Dockable
Security
Power On Authentication, HP Fast Charge, Pre-boot Authentication, Master Boot Record Security, Microsoft Security Defender
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, CCC, FCC, MIL-STD 810G, KCC, A-Tick, ICES, CIT, ICCP
Localization
1.48 kg
ENERGY STAR Certified
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP ZBook 14u G6 Intel Core i7-8565U 16GB 256GB SSD 14 Bundle deal on HP ZBook 14u G6 Intel Core i7-8565U 16GB 256GB SSD 14" Windows 10 Professional 64-bit
£1,074.71
Display Size: 14in
Optical Storage: None
Graphics: AMD Radeon Pro WX 3200 / Intel UHD Graphics 620
Hard Drive Type: SSD
Touchscreen: No
Type: Laptop
Brand: HP
Price Range Ex VAT: 750 - 1000
