HP ZBook 14u G5 Core i7-8550U 16GB 512GB SSD 14" Windows 10 Pro
Quicklinx: DWZ5WS00 Mfr#: 2ZC02EA#ABU
  • Core i7
  • IEEE 802.11n
Finally, workstation-class power meets thin and light design for executives on-the-go. With advanced features like quad core Intel Core processors and 3D professional graphics, you can view and edit high resolution files from anywhere.
  • Windows 10 Pro for Workstations
    Be productive in any situation with the power and security of Windows 10 Pro, enhanced with best-in-class collaboration and connectivity features from HP.
  • AMD 3D Radeon Pro Graphics
    Work with professional, certified discrete graphics for rich visual immersion and real-time visualization of complex, multi-layered files and projects.
  • Quad-core Intel Core processors
    Work at the speed of your ideas with the premium performance of the latest quad core Intel Core processors, and up to 4.2 GHz of turbo boost at your fingertips.
  • Software Certification
    HP mobile workstations undergo dozens of tests for software certification and optimized performance with the industry's leading software providers like Autodesk, Adobe, and more.
  • 4K Anti-Glare Display
    Work seamlessly on airplanes, trains or in cafes with a stunning optional 4K display, with anti-glare technology that improves the outdoor and direct light experience.
  • HP Premium Collaboration Keyboard
    Easily connect and collaborate with Skype and other conferencing tools. Conference key shortcuts include start/end call, view calendar, mute, and screen sharing.
HP ZBook 14u G5 Mobile Workstation - 14" - Intel Core i7 - 8550U - 16 GB RAM - 512 GB SSD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) - 8550U / 1.8 GHz, up to 4 GHz / 8 MB Cache
16 GB DDR4 (1 x 16 GB)
Storage
512 GB SSD - NVMe
Display
14" LED backlight 1920 x 1080 / Full HD - 157 ppi
Graphics
AMD Radeon Pro WX 3100 / Intel UHD Graphics 620
Video Memory
2 GB
Input Device
Keyboard, pointing stick, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 10 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Turbo silver
32.6 cm x 23.43 cm x 1.79 cm
1.48 kg
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (8th Gen) 8550U / 1.8 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
16 GB (1 x 16 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2400 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
512 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Pixel Density (ppi)
157
Full HD anti-glare
Audio & Video
Graphics Processor
Video Memory
2 GB
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
IR camera, Windows Hello
Sound
Stereo speakers, dual array microphone
Codec
CX7501
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch clickpad, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL), dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
50 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
Interfaces Details
USB 3.0 (charging) , Thunderbolt 3 , USB 3.0 , Headphone/microphone combo jack , LAN , Dock , HDMI
Turbo silver
Case Material
Aluminum, magnesium alloy
Dockable
Security
HP 3D DriveGuard, HP DuraKeys, soft-touch surface, HP BIOS Protection, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES, Common Criteria EAL4+
Localization
1.48 kg
Sustainability Information
TCO Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
DWZ5 HP 65W Smart AC Adapter In Stock £18.37
DWZ5 HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack In Stock £13.44
DWZ5 HP Dual Head Keyed Cable Lock In Stock £43.00
DWZ5 HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £147.06
DWZ5 HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £206.71
DWZ5 HP SS03050XL-PL - Laptop Battery - Li-Ion - 4.33 Ah - 50 Wh In Stock £50.80
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
DWZ5 HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site In Stock £123.80
Other bundles (6)
DWZ5 HP USB-C To VGA Adapter In Stock £22.68
DWZ5 HP USB Travel Mouse In Stock £10.14
DWZ5 HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
DWZ5 HP Premium Wireless Mouse In Stock £38.00
DWZ5 HP USB-C to DisplayPort Adapter In Stock £23.53
DWZ5 HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £144.44
