HP ZBook 14u G4 Core i7-7500 16GB 512GB SSD 14" Windows 10 Pro
Quicklinx: DPZ6WS00 Mfr#: 1RQ70EA#ABU
  • Core i7
Meet our thin and light HP ZBook 14u. This Ultrabook Workstation delivers an extraordinary level of power and graphics capability in a remarkably compact design. Now you can take workstation-class power anywhere you go.
  • Designed to move
    Hit the road in style with our thin and light mobile workstation. At 22 mm thin, as little as 1.64 kg (3.61 lbs) and impressive features like a 35.56 cm (14") touch or 4K UHD display, you'll be ready to innovate from anywhere.
  • Next-level power
    Step-up to workstation-class power with 3D graphics, the latest Intel Core i5 and i7 processors, up to 32 GB memory and 2 TB of storage. Plus, it's certified with leading software partners for fast performance across multiple apps.
  • No compromise reliability
    Confidently take on your workday with our durable & reliable HP ZBook 14u. With a 3-year limited warranty, 120,000 hours of testing, and 30 years of HP Z DNA this is where the fusion of innovation, performance & reliability meet.
HP ZBook 14u G4 Mobile Workstation - 14" - Intel Core i7 - 7500U - 16 GB RAM - 512 GB SSD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache
16 GB DDR4 (1 x 16 GB)
Storage
512 GB SSD - HP Z Turbo Drive G2, MLC
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
AMD FirePro W4190M / Intel HD Graphics 620
Video Memory
2 GB GDDR5 SDRAM
Input Device
Keyboard, touchpad, pointing stick
Keyboard
Keyboard Backlight
Integrated Webcam
Gigabit Ethernet
3-cell - up to 10 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
Space Silver
33.8 cm x 23.7 cm x 2.21 cm
1.64 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (7th Gen) 7500U / 2.7 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (1 x 16 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
512 GB SSD M.2 2280 PCIe - HP Z Turbo Drive G2, multi-level cell (MLC)
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Full HD ultra wide-viewing angle (UWVA) anti-glare
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video System Features
AMD Enduro technology
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording
Sound
Stereo speakers, two microphones
Codec
CX7501
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, touchpad with gesture support
Communications
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Miracast, Wake-on-LAN (WOL)
3-cell lithium polymer
51 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
Slots
1 x SIM card (1 free)
Interfaces Details
VGA , USB 3.0 (charging) , USB 3.1 Gen 1 , USB 3.0 , DisplayPort , Headphone/microphone combo jack , LAN , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC UHS-II Card)
Software
Software Included
Skype, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, HP Systems Software Manager (free download), HP Velocity, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Image Assistant (free download), HP JumpStart, HP JetAdvantage Connect, HP Noise Cancellation, HP MIK for Microsoft SCCM (free download), HP Client Security Suite Gen3
Space Silver
Case Material
Aluminum, magnesium alloy
Dockable
Security
HP 3D DriveGuard, HP DuraKeys, HP SpareKey, soft-touch surface, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES, Common Criteria EAL4+, low halogen
Localization
1.64 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
DPZ6 HP 90W Smart AC Adapter In Stock £22.69
DPZ6 HP 65W Smart AC Adapter In Stock £18.31
DPZ6 HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack In Stock £13.44
DPZ6 HP Dual Head Keyed Cable Lock In Stock £43.00
DPZ6 HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £206.71
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
DPZ6 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £94.03
Other bundles (6)
DPZ6 HPE DisplayPort to HDMI Adapter In Stock £13.44
DPZ6 HPE HP DisplayPort to DVI Adapter In Stock £17.23
DPZ6 HP USB-C To VGA Adapter In Stock £22.68
DPZ6 HP USB Travel Mouse In Stock £10.14
DPZ6 HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
DPZ6 HP Premium Wireless Mouse In Stock £38.00
