HP ZBook 14u Core i7-7500U 8GB 256GB SSD 14" Windows 10 Pro
Quicklinx: DC5MWS00 Mfr#: 1RQ68ET#ABU
Display Size: 14in
Processor Model: I7-7500U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i7
£1,626.12 ex VAT
£1,951.34 inc VAT
Deliver your best work on the go, using a sleek, ISV-certified mobile workstation Ultrabook, with impressive performance and 3D graphics capability to handle demanding workloads.
  • Designed to move
    Hit the road in style with our thin and light mobile workstation. At 22 mm thin, as little as 1.64 kg (3.61 lbs) and impressive features like a 35.56 cm (14") touch or 4K UHD display, you'll be ready to innovate from anywhere.
  • Next-level power
    Step-up to workstation-class power with 3D graphics, the latest Intel Core i5 and i7 processors, up to 32 GB memory and 2 TB of storage. Plus, it's certified with leading software partners for fast performance across multiple apps.
  • No compromise reliability
    Confidently take on your workday with our durable & reliable HP ZBook 14u. With a 3-year limited warranty, 120,000 hours of testing, and 30 years of HP Z DNA this is where the fusion of innovation, performance & reliability meet.
HP ZBook 14u G4 Mobile Workstation - 14" - Core i7 7500U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (7th Gen) 7500U / 2.7 GHz (3.5 GHz) / 4 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD HP Z Turbo Drive, NVMe
Optical Drive
No optical drive
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
AMD FirePro W4190M / Intel HD Graphics 620
Video Memory
2 GB GDDR5 SDRAM
Input Device
Pointing stick
Keyboard
Keyboard Backlight
Integrated Webcam
Gigabit Ethernet
3-cell - up to 10 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip
Space Silver
33.8 cm x 23.7 cm x 2.21 cm
1.64 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - HP Z Turbo Drive, NVM Express (NVMe)
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
300 cd/m²
Full HD standard-viewing angle (SVA) eDP anti-glare, 157 ppi
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video System Features
Shader Model 5.0, AMD Enduro technology
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Low light enhancement
Sound
Stereo speakers
High Definition Audio
Audio Features
Bang & Olufsen Audio
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, gesture function
Communications
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
3-cell lithium polymer
51 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
USB 3.0 (charging) , USB 3.0 , USB 3.1 Gen 1 , VGA , DisplayPort , LAN , Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Windows Defender, HP Velocity, HP Secure Erase, HP Security Manager, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Device Access Manager, HP 3D DriveGuard 6, HP Image Assistant (free download), HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP BIOSphere Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP System Software Manager (free download)
Space Silver
Case Material
Aluminum, magnesium alloy
Dockable
Security
HP DuraKeys, soft-touch surface, Automatic DriveLock, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES, Common Criteria EAL4+, low halogen
Localization
1.64 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP ZBook 14u Core i7-7500U 8GB 256GB SSD 14 Bundle deal on HP ZBook 14u Core i7-7500U 8GB 256GB SSD 14" Windows 10 Pro
£1,725.29
Display Size: 14in
Optical Storage: None
Graphics: AMD FirePro W4190M / Intel HD Graphics 620
Hard Drive Type: SSD
Touchscreen: No
Type: Laptop
Brand: HP
Price Range Ex VAT: 1500+
