HP Zbook 14u Core i5-7200U 8GB 256GB SSD 14" Windows 10 Pro
Quicklinx: DVD4WS00 Mfr#: 2ZC01ET#ABU
Display Size: 14in
Processor Model: I5-7200U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
£1,236.12 ex VAT
£1,483.34 inc VAT
Finally, workstation-class power meets thin and light design for executives on-the-go. With advanced features like quad core Intel Core processors and 3D professional graphics, you can view and edit high resolution files from anywhere.
  • Our thinnest and lightest mobile workstation
    Our redesigned ZBook has been customized for road warriors with a taste for sophistication at just 1.48 kg and 17.9 mm thin. Designed with metallic finishes and an optional 4K, touch display, you'll get a premium experience that travels light.
  • Premium power
    Power through your day using everything from spreadsheets to CAD with blazing fast HP Z Turbo Drive high speed storage and certified AMD Radeon Pro graphics.
  • Advanced protection from the inside out
    Industry-leading security features help keep your files and privacy safe while traveling. Optional HP Sure View guards your screen from prying eyes and HP Sure Click protects web browsing with hardware-enforced security.
HP ZBook 14u G5 Mobile Workstation - 14" - Core i5 7200U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD HP Z Turbo Drive, NVMe
Optical Drive
No optical drive
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
AMD Radeon Pro WX 3100 / Intel HD Graphics 620
Video Memory
2 GB GDDR5 SDRAM
Input Device
Pointing stick, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 10 hours
Dockable
Security
Fingerprint reader, smart card reader
32.6 cm x 23.43 cm x 1.79 cm
1.48 kg
Environmental Standards
TCO Certified Notebooks 5
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - HP Z Turbo Drive, NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
340 cd/m²
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, 157 ppi
Keyboard Name
HP Collaboration
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Windows Hello
Sound
Stereo speakers, dual array microphone
Codec
CX7501
Audio Features
Bang & Olufsen Audio
Input
Keyboard, pointing stick, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch clickpad, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL), dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
50 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
USB 3.0 (charging) , Thunderbolt 3 , USB 3.0 , Headphone/microphone combo jack , LAN , Dock , HDMI
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC UHS-II Card)
Case Material
Aluminum, magnesium alloy
Dockable
Security
HP 3D DriveGuard, HP DuraKeys, soft-touch surface, HP BIOS Protection, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES, Common Criteria EAL4+
Localization
1.48 kg
TCO Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP Zbook 14u Core i5-7200U 8GB 256GB SSD 14 Bundle deal on HP Zbook 14u Core i5-7200U 8GB 256GB SSD 14" Windows 10 Pro
£1,415.70
saving £2.42
£1,335.29
Display Size: 14in
Optical Storage: None
Graphics: AMD Radeon Pro WX 3100 / Intel HD Graphics 620
Hard Drive Type: SSD
Type: Laptop
Brand: HP
Price Range Ex VAT: 1000 - 1500
