HP ZBook 14 Intel Intel Core i7-5600U 16GB 256GB+512GB SSD 14" Windows 7 Professional 64-bit
Quicklinx: BKSWWS00 Mfr#: J8Z83EA#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Create anywhere using HP's thinnest and lightest ZBook workstation Ultrabook in a 14" diagonal screen size. This customizable workstation delivers impressive professional 3D graphics and outstanding performance even from the most demanding applications. All in all, an unprecedented sleek and stylish design.
  • Innovate anywhere
    Take powerful computing where you need to work. The ZBook 14 Mobile Workstation's innovative sleek design is impressive on the road, at client sites, and satellite offices. HP's workstation Ultrabook redefines mobile computing.
  • Optimize performance
    Get the performance you need with HP's thinnest and lightest mobile workstations equipped with Windows 8.1, the latest 5th generation Intel Core i5/i7 processors, professional AMD FirePro 3D graphics, optional touch and the HP Z Turbo Drive for exceptional storage performance.
  • Never lets you down
    Confidently take on your workday with the durable and reliable HP ZBook 14 or HP ZBook 15u. These ZBook mobile workstations are designed to undergo MIL-STD 810G testing and underwent 115,000 hours of testing in the HP Total Test Process. ISV-certifications help ensure that your ZBook works with the workstation applications you need to get the job done.
HP ZBook 14 G2 Mobile Workstation - 14" - Intel Core i7 - 5600U - 16 GB RAM - 256 GB SSD + 512 GB SSD - UK
Mobile workstation
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Intel Core i7 (5th Gen) - 5600U / 2.6 GHz, up to 3.2 GHz / 4 MB Cache
16 GB DDR3L (2 x 8 GB)
Storage
256 GB SSD - HP Z Turbo Drive + 512 GB SSD
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 5500
Input Device
Keyboard, touchpad, pointing stick
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, NFC, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Graphite, hematite
33.9 cm x 23.7 cm x 2.1 cm
1.71 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - carry-in , Limited warranty - battery - 3 years
Mobile workstation
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
CPU
Intel Core i7 (5th Gen) 5600U / 2.6 GHz
Max Turbo Speed
3.2 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (2 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
256 GB SSD M.2 PCIe - HP Z Turbo Drive
Secondary Storage
512 GB SSD SATA 6Gb/s
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
Installed Qty
1
Max Supported Qty
2
50 Wh
AC Adapter
Input
Output
65 Watt, 18.5 V
Connections & Expansion
4 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock , Battery
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
HP Recovery Disc Creator, LANDesk Management Suite, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, HP Spare Key, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP File Sanitizer, HP Security Manager, HP Disk Sanitizer External Edition (free download), HP BIOSphere, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP CIK for Microsoft SCCM, HP Device Access Manager
Graphite, hematite
Case Material
Aluminum, magnesium alloy
Dockable
Security
Security lock slot (cable lock sold separately), HP 3D DriveGuard, HP DuraFinish, One-Step Logon, HP DuraCase, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES
Localization
1.71 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
