HP Zbook 14 Intel Core i7-4600U 8GB 256GB SSD 14" Windows 8.1 Professional 64-bit
Quicklinx: 9R6DWS00 Mfr#: F0V14ET#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Everything you'd expect of the world's first workstation Ultrabook . HP's lightest mobile workstation – the new HP ZBook 14 utilizes impressive professional 3D graphics. This superbly thin, customizable workstation is light enough to carry when you're on the go – and powerful and reliable enough to carry you through the workday.
  • Exceptional innovation
    Take powerful computing where you need to work. The innovative sleek design is impressive on the road, at client sites, and satellite offices. The world's first workstation Ultrabook redefines mobile computing.Consolidate workstation resources and connect from any computer at any location. With HP Remote Graphics Software (RGS), you can collaborate with colleagues, or utilize the power of servers and workstations back at the office.Navigate designs, pan and zoom photos or touch your technical applications with the swipe of your finger. It's all at hand with an optional, intuitive 10-point multi-touch screen.
  • Engineered to perform
    HP's mobile workstation with the latest 4th generation Intel Core i5 or i7 processors is optimized for a great balance of energy efficiency and solid performance. Ideal for professional users needing battery life balance in a mobile workstation.See fine details in your work. The latest AMD FirePro graphics feature ISV certifications and Eyefinity technology that lets you run multiple display configurations with a single graphics card.Optimize this HP ZBook for peak performance. HP Performance Advisor configures your system with updated settings and drivers to help maximize performance.Get full power of graphics when you need them and longer battery life when using lighter graphic applications. It's automatic and seamless with hybrid graphics.
  • True mobile workstation reliability
    During the HP Total Test Process, mobile workstations experience 115,000 hours of performance trials, and with ISV-certifications, the HP ZBook 14 is reliable and ready for business.
  • Intelligent design
    No tools needed. Just unlatch the HP Easy Access Door to quickly service your hardware and upgrade parts.Quickly and easily transfer data and connect to devices. This mobile workstation is packed with multiple ports including USB 3.0 ports, DisplayPort 1.2, a media card slot and more.See clearly no matter what light you're in with an optional stylish backlit keyboard.
HP ZBook 14 Mobile Workstation - 14" - Intel Core i7 - 4600U - vPro - 8 GB RAM - 256 GB SSD
Mobile workstation
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Platform Technology
Intel vPro Platform
Intel Core i7 (4th Gen) - 4600U / 2.1 GHz, up to 3.3 GHz / 4 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
256 GB SSD - SED
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
AMD FirePro M4100 / Intel HD Graphics 4400
Video Memory
1 GB GDDR5 SDRAM
Input Device
Keyboard, touchpad, pointing stick
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
3-cell - up to 12.35 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Graphite, hematite
33.9 cm x 23.7 cm x 2.1 cm
1.59 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 3 years
Mobile workstation
Recommended Use
Small business, corporate business
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Processor / Chipset
CPU
Intel Core i7 (4th Gen) 4600U / 2.1 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Chipset
Intel QM87
Platform Technology
Intel vPro Platform
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD SATA 6Gb/s - Self-Encrypting Drive
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, Panel Self Refresh (PSR)
Audio & Video
Graphics Processor
Video Memory
1 GB GDDR5 SDRAM
Video System Features
AMD Dynamic Switchable Graphics
Camera
Video Resolutions
1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound
Input
Keyboard Backlight
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7260 - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
Remote Management Protocol
SNMP 2
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
Installed Qty
1
Max Supported Qty
2
50 Wh
Run Time
Up to 12.35 hours
AC Adapter
Input
Output
65 Watt, 18.5 V
Connections & Expansion
VGA , DisplayPort , Headphone/microphone combo jack , Dock , LAN , 4 x USB 3.0 , Battery
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, Computrace, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, HP ePrint, HP Setup, HP Hotkey Support, PDF Complete Corporate Edition, HP Performance Advisor, Microsoft Internet Explorer 9.0, CyberLink YouCam BE, HP Wallpaper, Microsoft Internet Explorer 10, Privacy Manager, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP Secure Erase, HP File Sanitizer, Box.net 50GB storage, Drive Encryption, HP Trust Circles Standard, HP Ceement, HP Manageability
Graphite, hematite
Case Material
Aluminum, magnesium alloy
Dockable
Security
Security lock slot (cable lock sold separately), HP 3D DriveGuard, HP DuraFinish, HP SpareKey, One-Step Logon, HP File Sanitizer, HP DuraCase, HP DisplaySafe, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, FIPS 140-2, KCC, WEEE, A-Tick, ICES
Localization
1.59 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance
40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
