Everything you'd expect of the world's first workstation Ultrabook . HP's lightest mobile workstation – the new HP ZBook 14 utilizes impressive professional 3D graphics. This superbly thin, customizable workstation is light enough to carry when you're on the go – and powerful and reliable enough to carry you through the workday.
Exceptional innovation
Take powerful computing where you need to work. The innovative sleek design is impressive on the road, at client sites, and satellite offices. The world's first workstation Ultrabook redefines mobile computing.Consolidate workstation resources and connect from any computer at any location. With HP Remote Graphics Software (RGS), you can collaborate with colleagues, or utilize the power of servers and workstations back at the office.Navigate designs, pan and zoom photos or touch your technical applications with the swipe of your finger. It's all at hand with an optional, intuitive 10-point multi-touch screen. -
Engineered to perform
HP's mobile workstation with the latest 4th generation Intel Core i5 or i7 processors is optimized for a great balance of energy efficiency and solid performance. Ideal for professional users needing battery life balance in a mobile workstation.See fine details in your work. The latest AMD FirePro graphics feature ISV certifications and Eyefinity technology that lets you run multiple display configurations with a single graphics card.Optimize this HP ZBook for peak performance. HP Performance Advisor configures your system with updated settings and drivers to help maximize performance.Get full power of graphics when you need them and longer battery life when using lighter graphic applications. It's automatic and seamless with hybrid graphics. -
True mobile workstation reliability
During the HP Total Test Process, mobile workstations experience 115,000 hours of performance trials, and with ISV-certifications, the HP ZBook 14 is reliable and ready for business. -
Intelligent design
No tools needed. Just unlatch the HP Easy Access Door to quickly service your hardware and upgrade parts.Quickly and easily transfer data and connect to devices. This mobile workstation is packed with multiple ports including USB 3.0 ports, DisplayPort 1.2, a media card slot and more.See clearly no matter what light you're in with an optional stylish backlit keyboard.
- HP ZBook 14 Mobile Workstation - 14" - Intel Core i5 - 4300U - vPro - 4 GB RAM - 500 GB HDD
- Product Type
- Mobile workstation
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (4th Gen) - 4300U / 1.9 GHz, up to 2.9 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Display
- 14" LED backlight HD+ SVA eDP anti-glare 1600 x 900 / HD+
- Graphics
- AMD FirePro M4100
- Video Memory
- 1 GB GDDR5 SDRAM
- Input Device
- Keyboard, touchpad, pointing stick
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 3-cell - up to 11 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- Graphite, hematite
- 33.9 cm x 23.7 cm x 2.1 cm
- 1.59 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - carry-in , Limited warranty - battery - 3 years
- Product Type
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4300U / 1.9 GHz
- Max Turbo Speed
- 2.9 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Chipset
- Intel QM87
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 7200 rpm
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- HD+ standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- AMD FirePro M4100
- Video Memory
- 1 GB GDDR5 SDRAM
- Video System Features
- AMD Dynamic Switchable Graphics
- Camera
- Video Resolutions
- 1280 x 720
- Camera Features
- Low light enhancement
- Sound
- Stereo speakers, stereo microphone
- Codec
- IDT 92HD91
- High Definition Audio, DTS Studio Sound
Input
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-N 7260AN - PCI Express Half Mini Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- Remote Management Protocol
- SNMP 2
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 3-cell lithium polymer
- Installed Qty
- 1
- Max Supported Qty
- 2
- Capacity
- 50 Wh
- Run Time
- Up to 11 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 18.5 V
Connections & Expansion
- 4 x USB 3.0 , DisplayPort , Headphone/microphone combo jack , LAN , Dock , VGA , Battery
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, Computrace, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, HP ePrint, HP Setup, HP Hotkey Support, PDF Complete Corporate Edition, HP Performance Advisor, CyberLink YouCam BE, HP Wallpaper, Microsoft Internet Explorer 10, Device Access Manager, Privacy Manager, HP Client Security, HP PageLift, HP Secure Erase, HP File Sanitizer, Drive Encryption, HP Trust Circles Standard, HP Disk Sanitizer, HP Ceement, HP Manageability, HP Validity Fingerprint Driver
- Case Material
- Aluminum, magnesium alloy
- Dockable
- Security
- Security lock slot (cable lock sold separately), HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP SpareKey, One-Step Logon, HP File Sanitizer, HP DuraCase, HP DisplaySafe, HP BIOS Protection, HP SureStart, 1 USB 3.0 (powered), SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, FIPS 140-2, KCC, WEEE, A-Tick, ICES
- Localization
- 1.59 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance
- 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
