Brand
HP ZB17G7 I710750H 32GB/512GB W10P
Quicklinx: G7BLWS00 Mfr#: 119Y6EA#ABU
Display Size: 17.3in
Processor Model: I7-10750H
Operating System: Windows 10 Pro 64-bit Edition
Hard Drive Capacity: 512GB
Optical Storage: None
  • Core i7
  • IEEE 802.11n
£2,419.79 ex VAT
£2,903.74 inc VAT
HP's thinnest and most powerful 17" performance mobile workstation packs the relentless power of our ultimate ZBook into a dramatically smaller design. Create, render, edit, and simulate with ease. Visualize complex datasets in the field. Incredible performance has never been so portable.
  • Windows 10 Pro for Workstations 64
    Work without compromising on performance or security with Windows 10 Pro for Workstations, powered by HP's collaboration and connectivity technology.
  • Intel Core i7 processor
    Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor.
  • HP Z Turbo Drive High-speed Storage
    Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage.
  • Spill-resistant Keyboard
    Accidents happen - which is why we designed our keyboard with a drain hole, so minor spills flow out the bottom for easy cleanup.
  • Industry-leading security features
    Advanced security features come standard. System safeguards like HP Sure Start – the industry's first self-healing BIOS – mean your device is locked down tight, so your data and identity are too.
HP ZBook Fury 17 G7 Mobile Workstation - 17.3" - Core i7 10750H - 32 GB RAM - 512 GB SSD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (10th Gen) 10750H / 2.6 GHz (5 GHz) / 12 MB Cache
32 GB DDR4 (1 x 32 GB)
Storage
512 GB SSD - NVMe
Display
17.3" WLED 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro T2000 / Intel UHD Graphics
Video Memory
4 GB GDDR6 SDRAM
Input Device
Keyboard, touchpad, pointing stick
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax, Gigabit Ethernet
8-cell - up to 15.75 hours
Ambient light sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
39.84 cm x 26.71 cm x 2.69 cm
2.76 kg
Environmental Standards
TCO Certified Notebooks 8, ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
5 GHz
Number of Cores
6-core
Cache
12 MB
64-bit Computing
Chipset
Mobile Intel WM490
Intel Turbo Boost Technology
RAM
32 GB (1 x 32 GB)
Max RAM Supported
128 GB
DDR4 SDRAM - non-ECC
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
3
Storage
Main Storage
512 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
17.3" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
300 cd/m²
Colour Gamut
72%
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Keyboard Name
HP Premium Quiet Keyboard
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR6 SDRAM
Camera
Yes - HD
Video Resolutions
720p
Camera Features
IR camera
Sound
Stereo speakers, HP World Facing Microphone / dual-array digital microphone
High Definition Audio
Audio Features
Bang & Olufsen Audio
Input
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Programmable buttons, spill-resistant, multi-touch touchpad, gesture function, precision touchpad, glass touchpad
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wi-Fi 6 AX 201 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Dual stream (2x2), CNVi
IEEE 802.11d, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v
8-cell lithium polymer
94 Wh
Run Time
Up to 15.75 hours
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
USB 3.1 Gen 1 (charging) , Mini DisplayPort 1.4 , 2 x USB 3.1 Gen 1 , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.4 Alt Mode) (BC1.2 charging) , HDMI , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
HP Support Assistant, Bing Toolbar, HP Hotkey Support, HP Performance Advisor, Windows Defender, HP Device Access Manager, HP Image Assistant, HP Noise Cancellation, Native Miracast, HP Connection Optimizer, HP Sure Recover, HP BIOSphere Gen5, HP Client Security Manager Gen5, HP Cloud Recovery, HP Manageability Integration Kit Gen4 (free dowload), HP ZCentral Remote Boost, myHP
Integrated Options
Security
HP DuraKeys, Power On Authentication, Pre-boot Authentication, Master Boot Record Security, MIL-STD-810H tested
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
HP 150W Slim Smart AC Adapter
CSA, UL, VCCI, BSMI, GOST, CCC, FIPS 140-2 Level 2, FCC, RoHS, KCC, WEEE, A-Tick, ICES, Common Criteria EAL4+, low halogen, ICCP
Localization
2.76 kg
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (4)
Get more from your purchase from one of our essential accessories
G7BL HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack In Stock £13.40
G7BL HP Keyed Cable Lock 10mm In Stock £27.41
G7BL HP Dual Head Keyed Cable Lock In Stock £43.00
G7BL HP Thunderbolt Dock 120W G2 with Audio In Stock £296.47
Other bundles (15)
G7BL HPE HDMI to DVI Adapter In Stock £10.00
G7BL HP USB Travel Mouse In Stock £8.88
G7BL HP X4000b Bluetooth Mouse In Stock £27.41
G7BL HP Slim Wireless Keyboard and Mouse In Stock £54.36
G7BL HP Presenter MouseRemote control In Stock £74.35
G7BL HP EliteDisplay E243m 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £203.04
G7BL HP EliteDisplay E273m 27" 1920x1080 5ms VGA HDMI DisplayPort USB-C IPS LED Monitor In Stock £233.33
G7BL HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
G7BL HP Z38c 37.5" 3840x1600 5ms HDMI DisplayPort USB-C Curved IPS LED Monitor In Stock £798.42
G7BL HP USB-C to DisplayPort Adapter In Stock £23.53
G7BL HP USB-C to HDMI 2.0 Adapter In Stock £17.40
G7BL HP USB-C to USB 3.0 In Stock £20.71
G7BL HP P22h G4 21.5" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £180.00
G7BL HP E23 G4 23" 1920x1080 5ms USB VGA HDMI FHD Monitor In Stock £199.16
G7BL HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £191.77
Graphics: NVIDIA Quadro T2000 / Intel UHD Graphics
Hard Drive Type: SSD
Brand: HP
Price Range Ex VAT: £1500+
