HP Z840 Workstation MT Intel Xeon E5-2640v3(x2) 32GB 1TB Windows 7 Professional 64-bit
Quicklinx: BD4BWS00 Mfr#: J9B53EA#ABU
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
Push your computing boundaries with the HP Z840 Workstation that helps you keep up with your biggest projects. Built for high-end computing and visualization, it delivers outstanding performance in one of the industry's most expandable chassis.
  • Powerful processing
    Achieve the performance you need with the ability to support two next generation Intel Xeon processors for up to 36 total processor cores in one system.
  • Geared up graphics
    Take productivity up a notch with the ability to do more thanks to NVIDIA professional graphics cards in 2D or 3D.
  • See the difference
    Get serious about graphics and reach peak productivity with access to a breadth of AMD professional graphics from entry to high-end 3D.
  • Powerhouse ports
    Maximize your time and increase your capabilities with USB and SATA ports, plus lightning-fast data transfers using optional Thunderbolt 2 technology.
  • A new design to fit your needs
    A new tool-free chassis boasts low acoustics, dual integrated Gb Ethernet, aluminum side panels, handles for lifting, and is 5U rack mountable-all in an elegant industrial design.
  • Set a new performance curve for your HP Z840
    Reduce boot up, calculation, and graphics response and revolutionize how your HP Z840 handles large files with the HP Z Turbo Drive, a remarkably fast and innovative storage solution.
HP Workstation Z840 - MT - Xeon E5-2640V3 2.6 GHz - vPro - 32 GB - HDD 1 TB - UK
Workstation - mini tower - power-on password, serial port I/O control, USB port control, audio ports control, network port control, Setup Password
Platform Technology
Intel vPro Platform
2 x Intel Xeon E5-2640V3 / 2.6 GHz (, up to 3.4 GHz, (8-core)
Processor Socket
LGA2011-v3 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
40 MB
Cache Per Processor
20 MB
RAM
32 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
SAS-2 (SAS 6Gb/s); RAID (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
PCIe 2.0 x16 - NVIDIA Quadro K4200
Video Memory
4 GB GDDR5 SDRAM
Audio Output
Integrated
1GbE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Software Included
Windows 7 Professional 64-bit recovery DVD
Black, hematite
20.3 cm x 52.5 cm x 44.4 cm
21.1 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Mini tower
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Black, hematite
Processor / Chipset
CPU
Clock Speed
2.6 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
8-core
CPU Qty
2
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
40 MB
Cache Per Processor
20 MB
RAM
Installed Size
32 GB / 256 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
1866 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
16 (Total) / 8 (empty)
Registered
Configuration Features
8 x 4 GB
RAM Supported
256 GB registered - ECC , 2 TB Load-Reduced - ECC
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SAS-2 - integrated
Controller Interface Type
SAS 6Gb/s
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 10
Storage Controller (2nd)
1 x RAID - integrated
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Plug-in card
Interface Type
PCIe 2.0 x16
Graphics Processor
NVIDIA Quadro K4200
Video Memory
4 GB GDDR5 SDRAM
Video Interfaces
DVI, DisplayPort
Audio Output
Integrated
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I218-LM, I210-AT
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3ap, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 4 (total) / 3 (free) x internal 3.5"
Slots
2 (total) / 0 (free) x CPU , 16 (total) / 8 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x4 , 2 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x8 (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 3.0 x16 (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 2.0 x1 , 1 (total) / 1 (free) x PCIe 2.0 x4
8 x USB 3.0 (4 front, 4 rear) , 2 x USB 2.0 , 1 x PS/2 mouse , 1 x PS/2 keyboard , 2 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x microphone (1 in front) , 1 x audio line-out , 1 x headphones/microphone (1 in front) , 1 x serial , 1 x DVI-I (dual link) , 2 x DisplayPort
HP Dual Processor Air Cooling Kit
DisplayPort-DVI adapter
Power-on password, serial port I/O control, USB port control, audio ports control, network port control, Setup Password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI 2.0, RoHS, WEEE
Power supply
Power Provided
1125 Watt
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence - English
Software
20.3 cm
52.5 cm
44.4 cm
21.1 kg
5 °C
35 °C
8 - 85% (non-condensing)
