HP Z840 Workstation MT Intel Xeon E5-2620v3 16GB 1TB Windows 7 Professional 64-bit
Quicklinx: B024WS00 Mfr#: G1X56ET#ABU
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
Push your computing boundaries with the HP Z840 Workstation that helps you keep up with your biggest projects. Built for high-end computing and visualization, it delivers outstanding performance in one of the industry's most expandable chassis.
  • Powerful processing
    Achieve the performance you need with the ability to support two next generation Intel Xeon processors for up to 36 total processor cores in one system.
  • Geared up graphics
    Take productivity up a notch with the ability to do more thanks to NVIDIA professional graphics cards in 2D or 3D.
  • See the difference
    Get serious about graphics and reach peak productivity with access to a breadth of AMD professional graphics from entry to high-end 3D.
  • Powerhouse ports
    Maximize your time and increase your capabilities with USB and SATA ports, plus lightning-fast data transfers using optional Thunderbolt 2 technology.
  • A new design to fit your needs
    A new tool-free chassis boasts low acoustics, dual integrated Gb Ethernet, aluminum side panels, handles for lifting, and is 5U rack mountable-all in an elegant industrial design.
  • Set a new performance curve for your HP Z840
    Reduce boot up, calculation, and graphics response and revolutionize how your HP Z840 handles large files with the HP Z Turbo Drive, a remarkably fast and innovative storage solution.
HP Workstation Z840 - MT - Xeon E5-2620V3 2.4 GHz - vPro - 16 GB - HDD 1 TB
Workstation - mini tower - power-on password, serial port I/O control, USB port control, audio ports control, network port control, Setup Password
Platform Technology
Intel vPro Platform
1 x Intel Xeon E5-2620V3 / 2.4 GHz (, up to 3.2 GHz, (6-core)
Processor Socket
LGA2011-v3 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
16 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
SAS-2 (SAS 6Gb/s); SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
15 in 1
Graphics Controller
No graphics
Audio Output
Integrated
1GbE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, HP Power Assistant, PDF Complete Corporate Edition, HP Performance Advisor, HP Remote Graphics Software 5
Black, hematite
20.3 cm x 52.5 cm x 44.4 cm
21.1 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Mini tower
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Black, hematite
Processor / Chipset
CPU
Clock Speed
2.4 GHz
Max Turbo Speed
3.2 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
16 GB / 256 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
1866 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
16 (Total) / 14 (empty)
Registered
Configuration Features
2 x 8 GB
RAM Supported
256 GB registered - ECC , 512 GB Load-Reduced - ECC
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SAS-2 - integrated
Controller Interface Type
SAS 6Gb/s
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 10
Storage Controller (2nd)
1 x SATA - integrated
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
15 in 1 card reader
Supported Flash Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, SDHC Memory Card, Memory Stick PRO-HG Duo, SDXC Memory Card, Memory Stick Select, SDHC UHS-II Memory Card, SDXC UHS-II Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
Integrated
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
USB
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I218-LM, I210-AT
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3ap, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x external 5.25" x 1/2H , 4 (total) / 3 (free) x internal 3.5" x 1/3H
Slots
2 (total) / 1 (free) x CPU , 16 (total) / 14 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x4 , 2 (total) / 2 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x8 (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 3.0 x16 (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 2.0 x1 , 1 (total) / 1 (free) x PCIe 2.0 x4
8 x USB 3.0 (4 front, 4 rear) , 2 x USB 2.0 , 1 x PS/2 mouse , 1 x PS/2 keyboard , 2 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x microphone (1 in front) , 1 x audio line-out , 1 x headphones/microphone (1 in front) , 1 x serial
Power-on password, serial port I/O control, USB port control, audio ports control, network port control, Setup Password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI 2.0, RoHS, WEEE
Power supply
Power Provided
1125 Watt
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Software
20.3 cm
52.5 cm
44.4 cm
21.1 kg
5 °C
35 °C
8 - 85% (non-condensing)
B024 HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
B024 HP E23 G4 23" 1920x1080 5ms USB VGA HDMI FHD Monitor In Stock £148.74
B024 HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £144.44
