HP Z840 Workstation MT Intel Xeon E5-2620v3 16GB 1TB Windows 7 Professional 64-bit
Quicklinx: B024WS00 Mfr#: G1X56ET#ABU
Processor Type: Xeon
Operating System: Microsoft Windows 7 Professional 64-bit Edition
Installed Memory: 16GB, 16GB
Hard Drive Capacity: 1TB
Storage Type: HDD
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
£1,816.99 ex VAT
£2,180.38 inc VAT
Push your computing boundaries with the HP Z840 Workstation that helps you keep up with your biggest projects. Built for high-end computing and visualization, it delivers outstanding performance in one of the industry's most expandable chassis.
  • Prepare to be spectacular
    The HP Z840 Workstation, HP's highest performing workstation gets the best of HP Z DNA with incredible processing power, professional graphics, maximized memory, and internal storage capacity that helps you create work that makes a statement.
  • Get going
    Experience expansion like you never dreamed possible with 7 PCIe slots, up to 10 internal drive bays, and 16 memory slots supporting up to 2TB of memory the HP Z840 can do it all. Ready to get going?
  • Keep going
    Reach your goals with the HP Z840 Workstation featuring uncompromised reliability, a tool-less chassis to facilitate upgrades, a rackable option in addition to a desk side system, a lockable side panel, and handles to move the system around.
HP Workstation Z840 - MT - Xeon E5-2620V3 2.4 GHz - 16 GB - 1 TB
Workstation - mini tower
Platform Technology
Intel vPro Technology
1 x Intel Xeon E5-2620V3 / 2.4 GHz (3.2 GHz) (6-core)
Processor Socket
LGA2011-v3 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
16 GB (installed) / 256 GB (max) DDR4 SDRAM - ECC - PC4-17000
Storage Controller
SAS-2 (SAS 6Gb/s); SATA (SATA 6Gb/s)
Hard Drive
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
15 in 1
Graphics Controller
No graphics
Audio Output
Integrated
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Black, hematite
20.3 cm x 52.5 cm x 44.4 cm
21.1 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Workstation
Product Form Factor
Mini tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Black, hematite
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
16 GB / 256 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
1866 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
16 (Total) / 14 (empty)
Registered
Configuration Features
2 x 8 GB
RAM Supported
256 GB registered - ECC , 512 GB Load-Reduced - ECC
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SAS-2 - integrated
Controller Interface Type
SAS 6Gb/s
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 10
Storage Controller (2nd)
1 x SATA - integrated
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD SuperMulti - SATA
Card Reader
15 in 1 card reader
Supported Flash Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, SDHC Memory Card, Memory Stick PRO-HG Duo, SDXC Memory Card, Memory Stick Select, SDHC UHS-II Memory Card, SDXC UHS-II Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
Integrated
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
USB
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I218-LM, I210AT
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3ap, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x external 5.25" x 1/2H , 4 (total) / 3 (free) x internal 3.5" x 1/3H
Slots
2 (total) / 1 (free) x CPU , 16 (total) / 14 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x4 , 2 (total) / 2 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x8 (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 3.0 x16 (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 2.0 x1 , 1 (total) / 1 (free) x PCIe 2.0 x4
8 x USB 3.0 (4 front, 4 rear) , 2 x USB 2.0 , 1 x PS/2 mouse , 1 x PS/2 keyboard , 2 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x microphone (1 in front) , 1 x audio line-out , 1 x headphones/microphone (1 in front) , 1 x serial
Power-on password, serial port I/O control, USB port control, audio ports control, network port control, Setup Password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI 2.0, RoHS, WEEE
Power supply
Nominal Voltage
Power Provided
1125 Watt
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Software
Cyberlink PowerDVD, CyberLink Power2Go, HP Power Assistant, PDF Complete Corporate Edition, HP Performance Advisor, HP Remote Graphics Software 5
20.3 cm
52.5 cm
44.4 cm
21.1 kg
5 °C
35 °C
8 - 85% (non-condensing)
Storage Type: HDD
Processor Model: E5-2620V3
Type: Workstation
Case Style: Mini tower
Display: no
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Brand: HP
Price Range Ex VAT: 1500+
