Push your computing boundaries with the HP Z840 Workstation that helps you keep up with your biggest projects. Built for high-end computing and visualization, it delivers outstanding performance in one of the industry's most expandable chassis.
Powerful processing
Achieve the performance you need with the ability to support two next generation Intel Xeon processors for up to 36 total processor cores in one system. -
Geared up graphics
Take productivity up a notch with the ability to do more thanks to NVIDIA professional graphics cards in 2D or 3D. -
See the difference
Get serious about graphics and reach peak productivity with access to a breadth of AMD professional graphics from entry to high-end 3D. -
Powerhouse ports
Maximize your time and increase your capabilities with USB and SATA ports, plus lightning-fast data transfers using optional Thunderbolt 2 technology. -
A new design to fit your needs
A new tool-free chassis boasts low acoustics, dual integrated Gb Ethernet, aluminum side panels, handles for lifting, and is 5U rack mountable-all in an elegant industrial design. -
Set a new performance curve for your HP Z840
Reduce boot up, calculation, and graphics response and revolutionize how your HP Z840 handles large files with the HP Z Turbo Drive, a remarkably fast and innovative storage solution.
- HP Workstation Z840 - MT - Xeon E5-2680V3 2.5 GHz - vPro - 32 GB - SSD 512 GB
- Workstation - mini tower - power-on password, serial port I/O control, USB port control, audio ports control, network port control, Setup Password
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- 1 x Intel Xeon E5-2680V3 / 2.5 GHz (, up to 3.3 GHz, (12-core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 30 MB
- Cache Per Processor
- 30 MB
- RAM
- 32 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- SAS-2 (SAS 6Gb/s); SATA (SATA 3Gb/s)
- Hard Drive
- SSD 512 GB - PCI Express 2.0 x4
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- No graphics
- Audio Output
- Integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- Black, hematite
- 20.3 cm x 52.5 cm x 44.4 cm
- 21.1 kg
- Workstation
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Mini tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Black, hematite
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-2680V3
- Clock Speed
- 2.5 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- 12-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 30 MB
- 30 MB
RAM
- Installed Size
- 32 GB / 256 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 8 (Total) / 4 (empty)
- Registered
- Configuration Features
- 4 x 8 GB
- RAM Supported
- 256 GB registered , 2 TB Load-Reduced
Hard Drive
- SSD
- Capacity
- 1 x 512 GB
- Interface Type
Storage Controller
- 1 x SAS-2 - integrated
- Controller Interface Type
- SAS 6Gb/s
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 10
Storage Controller (2nd)
- 1 x SATA - integrated
- SATA 3Gb/s
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- Integrated
- High Definition Audio
Input Device
- Keyboard
Keyboard
- Interface
- USB
- Integrated
- Interface (Bus) Type
- PCI Express 1.1 x1
- Ethernet Controller
- Intel I218-LM
- Data Link Protocol
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az
- Bays
- 2 (total) / 2 (free) x external 5.25" , 4 (total) / 4 (free) x internal 3.5" , 1 (total) / 0 (free) x external 5.25" Slim Line
- Slots
- 2 (total) / 1 (free) x CPU , 8 (total) / 4 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x4 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 2.0 x1 - full-length, full-height , 1 (total) / 0 (free) x PCIe 2.0 x4 - full-length, full-height
- 8 x USB 3.0 (4 front, 4 rear) , 2 x USB 2.0 , 1 x PS/2 mouse , 1 x PS/2 keyboard , 2 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x microphone (1 rear) , 1 x audio line-out , 1 x headphones (1 rear)
- Power-on password, serial port I/O control, USB port control, audio ports control, network port control, Setup Password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS, ACPI 2.0c, WEEE
- Power supply
- Voltage Required
- Power Provided
- 1450 Watt
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- 20.3 cm
- 52.5 cm
- 44.4 cm
- 21.1 kg
- 5 °C
- 35 °C
- 8 - 85% (non-condensing)
