Redefine versatility and flexibility. Expand your capabilities with HP's Z640 Workstation offering powerful performance, whisper-quiet computing, and tool-less access in compact design.
Primed to perform
Achieve the performance you need with the ability to support two next generation Intel Xeon processors for up to 36 total processor cores in one system. -
See everything clearly
Take productivity up a notch with the ability to do more thanks to NVIDIA professional graphics cards in 2D or 3D. -
Graphics pro
Get serious about graphics and reach peak productivity with access to a breadth of AMD professional graphics from entry to high-end 3D. -
High-power ports
Maximize your time and increase your capabilities with USB and SATA ports, plus lightning-fast data transfers using optional Thunderbolt 2 technology. -
Conveniently compact
A tool-free chassis boasts low acoustics, single integrated Gb Ethernet, a front and rear handle, rear ledge and is 4U rack mountable-all in a compact design. -
Set a new performance curve for your HP Z640
Reduce boot up, calculation, and graphics response and revolutionize how your HP Z640 handles large files with the HP Z Turbo Drive, a remarkably fast and innovative storage solution.
- HP Workstation Z640 - MT - Xeon E5-2650V3 2.3 GHz - vPro - 32 GB - SSD 512 GB
- Workstation - mini tower - power-on password, Setup Password
- Platform Technology
- Intel vPro Platform
- Height (Rack Units)
- 4U
- Localisation
- Processor
- 1 x Intel Xeon E5-2650V3 / 2.3 GHz (, up to 3 GHz, (10-core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 25 MB
- Cache Per Processor
- 25 MB
- RAM
- 32 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 512 GB - PCI Express 2.0 x4
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- No graphics
- Audio Output
- Integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- Black, hematite brushed aluminium
- 17.15 cm x 46.48 cm x 44.45 cm
- 15 kg
- Workstation
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Mini tower - 4U
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-2650V3
- Clock Speed
- 2.3 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 10-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 25 MB
- 25 MB
RAM
- Installed Size
- 32 GB / 256 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 0 (empty)
- Registered
- Configuration Features
- 4 x 8 GB
Hard Drive
- SSD
- Capacity
- 1 x 512 GB
- Interface Type
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- Integrated
- High Definition Audio
Input Device
- Keyboard
Keyboard
- Interface
- USB
- Integrated
- Interface (Bus) Type
- PCI Express 1.1 x1
- Ethernet Controller
- Intel I218-LM
- Data Link Protocol
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az
- Bays
- 2 (total) / 2 (free) x external 5.25" , 3 (total) / 2 (free) x internal 3.5" , 1 (total) / 0 (free) x external 5.25" Slim Line
- Slots
- 2 (total) / 1 (free) x CPU , 4 (total) / 0 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x1 - full-length, full-height
- 8 x USB 3.0 (4 front, 4 rear) , 2 x USB 2.0 , 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x microphone (1 rear) , 1 x audio line-out , 1 x headphones (1 rear)
- Included Accessories
- Handle in Top Optical Bay
- Power-on password, Setup Password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI 2.0, RoHS, WEEE
- Power supply
- Voltage Required
- Power Provided
- 925 Watt
- 80 PLUS Certification
- 80 PLUS
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- 17.15 cm
- 46.48 cm
- 44.45 cm
- 15 kg
- 5 °C
- 35 °C
- 8 - 85% (non-condensing)
