HP Z640 - MT - 4U - 1 x Xeon E5-2630V3 / 2.4 GHz
Quicklinx: DC1LWS00 Mfr#: 2WT90ET#ABU
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
Redefine versatility and flexibility. Expand your capabilities with HP's Z640 Workstation offering powerful performance, whisper-quiet computing, and tool-less access in compact design.
  • Power up
    Experience massive workstation power with support for 145W processors powering up to 36 cores in a dual Intel Xeon processor configuration. The HP Z640 Workstation uses Z DNA to provide a high-end workstation experience.
  • Versatility redefined
    Build the perfect workstation for your needs. The HP Z640 Workstation featuring Windows 8.1 provides incredible expansion in a small footprint. With up to 8 memory DIMMs, up to 4 internal hard drives, optional Thunderbolt 2, and the HP Z Turbo Drive, you get storage, performance, and the freedom to create.
  • Experience the quiet
    Concentrate on your work using a workstation that is whisper quiet. When every inch, watt, and decibel makes a difference, count on the HP Z640 Workstation.
HP Workstation Z640 - MT - Xeon E5-2630V3 2.4 GHz - 16 GB - 256 GB - UK
Workstation - mini tower
Platform Technology
Intel vPro Technology
Height (Rack Units)
4U
1 x Intel Xeon E5-2630V3 / 2.4 GHz (3.2 GHz) (8-core)
Processor Socket
LGA2011-v3 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
20 MB
Cache Per Processor
20 MB
RAM
16 GB (installed) / 128 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 256 GB - PCI Express 2.0 x4 - PCI Express - HP Z Turbo Drive, multi-level cell (MLC)
Optical Storage
DVD-Writer
Graphics Controller
No graphics
GigE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
HP black, hematite brushed aluminium
17.145 cm x 46.48 cm x 44.29 cm
15 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Workstation
Product Form Factor
Mini tower - 4U
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
20 MB
Cache Per Processor
20 MB
RAM
Installed Size
16 GB / 128 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
1866 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Registered, quad channel memory architecture
Configuration Features
2 x 8 GB
RAM Supported
128 GB registered , 256 GB Load-Reduced
Hard Drive
SSD - PCI Express
1 x 256 GB
Interface Type
PCI Express 2.0 x4
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Laser
USB
Ethernet Controller
Intel I218-LM
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 2 (total) / 2 (free) x internal 3.5"
Slots
2 (total) / 1 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height , 1 (total) / 0 (free) x PCIe 2.0 x4 - full-length, full-height
8 x USB 3.0 (4 front, 4 rear) , 2 x USB 2.0 , 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x microphone (1 in front) , 1 x audio line-out , 1 x headphones/microphone (1 in front)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, ACPI 4.0, low halogen
Power supply
Nominal Voltage
Power Provided
925 Watt
80 PLUS Certification
80 PLUS
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
17.145 cm
46.48 cm
44.29 cm
15 kg
5 °C
35 °C
8 - 85% (non-condensing)
