More versatile than ever before. The HP Z620 Workstation delivers twice the memory capacity of the previous generation, a larger power supply and support for single or dual socket processor configurations.
Big possibilities, compact form factor
With its innovative design, the HP Z620 Workstation gives you a near silent computing solution in a form factor that's a perfect fit for space-constrained environments. And for easy servicing and upgrades, it features a completely tool-less chassis with integrated handles and a tool-free power supply. -
The performance you demand
Get massive system performance with a small footprint. The HP Z620 features the next evolution in processor technology and system architecture, setting the standard for versatility with support for Xeon processors. -
Bring your ideas to life faster
The HP Z620 is designed to support next generation PCIe Gen3 graphics technology that doubles the bandwidth in and out of the card. And with an 800W 90% efficient power supply and support for up to 8 displays, the HP Z620 gives you the freedom of doing and seeing more.
- HP Workstation Z620 - MT - Xeon E5-2620 2 GHz - 16 GB - 1 TB
- Workstation - mini tower
- Platform Technology
- Intel vPro Technology
- Height (Rack Units)
- 4U
- Localisation
- Processor
- 1 x Intel Xeon E5-2620 / 2 GHz (2.5 GHz) (6-core)
- Processor Socket
- LGA2011 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology
- Cache Memory
- 15 MB
- Cache Per Processor
- 15 MB
- RAM
- 16 GB (installed) / 96 GB (max) - DDR3 SDRAM - ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s); SATA (SATA 3Gb/s)
- Hard Drive
- 1 x 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- 22 in 1
- Graphics Controller
- No graphics
- Audio Output
- Integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
- Microsoft Office Preloaded
- Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
- Black, brushed aluminum
- 17.15 cm x 46.48 cm x 44.45 cm
- 15.5 kg
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Mini tower - 4U
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-2620 / 2 GHz
- Max Turbo Speed
- 2.5 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011 Socket
- Chipset Type
- Intel C602
Cache Memory
- Installed Size
- 15 MB
- 15 MB
RAM
- Installed Size
- 16 GB / 96 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 8 (Total) / 4 (empty)
- Unbuffered
- Configuration Features
- 4 x 4 GB
- RAM Supported
- PC3-12800 - 96 GB registered - ECC , PC3-12800 - 48 GB unbuffered - ECC
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ)
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 2
- RAID Level
- RAID 0, RAID 1
Storage Controller (2nd)
- SATA 3Gb/s
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD SuperMulti - SATA
Card Reader
- 22 in 1 card reader
- Supported Flash Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, RS-MMC, microSD, SDHC Memory Card, microSDHC, Memory Stick PRO-HG Duo, SDXC Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- Integrated
- High Definition Audio
Input Device
- Mouse
Mouse
- Technology
- Laser
- Interface
- USB
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel 82574L, Intel 82579LM
- Data Link Protocol
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Bays
- 2 (total) / 1 (free) x external 5.25" x 1/2H , 3 (total) / 2 (free) x internal 3.5" x 1/3H
- Slots
- 2 (total) / 1 (free) x CPU , 8 (total) / 4 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height (x1 mode) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height
- 4 x USB 3.0 (2 front, 2 rear) , 5 x USB 2.0 (1 front, 4 rear) , 1 x PS/2 mouse , 1 x PS/2 keyboard , 2 x LAN (Gigabit Ethernet) , 1 x audio line-in , 2 x microphone (1 front, 1 rear) , 1 x audio line-out , 1 x headphones (1 in front) , 2 x FireWire (1 front, 1 rear)
- System password, power-on password
- ACPI 2.0, RoHS, WEEE
- Power supply
- Nominal Voltage
- Power Provided
- 800 Watt
- 80 PLUS Certification
- 80 PLUS
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
- Software
- Intervideo WinDVD, Roxio Easy Media Creator, HP Support Assistant, HP Power Assistant, PDF Complete (Trial), HP Performance Advisor
- 17.15 cm
- 46.48 cm
- 44.45 cm
- 15.5 kg
- 5 °C
- 35 °C
- 8 - 85% (non-condensing)
