HP Z620 Workstation MT Intel Xeon E5-2620 16GB 1TB Windows 7 Professional 64-bit
Quicklinx: 8R84WS00 Mfr#: WM523ET#ABU
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
More versatile than ever before. The HP Z620 Workstation delivers twice the memory capacity of the previous generation, a larger power supply and support for single or dual socket processor configurations.
  • Big possibilities, compact form factor
    With its innovative design, the HP Z620 Workstation gives you a near silent computing solution in a form factor that's a perfect fit for space-constrained environments. And for easy servicing and upgrades, it features a completely tool-less chassis with integrated handles and a tool-free power supply.
  • The performance you demand
    Get massive system performance with a small footprint. The HP Z620 features the next evolution in processor technology and system architecture, setting the standard for versatility with support for Xeon processors.
  • Bring your ideas to life faster
    The HP Z620 is designed to support next generation PCIe Gen3 graphics technology that doubles the bandwidth in and out of the card. And with an 800W 90% efficient power supply and support for up to 8 displays, the HP Z620 gives you the freedom of doing and seeing more.
HP Workstation Z620 - MT - Xeon E5-2620 2 GHz - vPro - 16 GB - HDD 1 TB
Workstation - mini tower - system password, power-on password
Platform Technology
Intel vPro Platform
Height (Rack Units)
4U
1 x Intel Xeon E5-2620 / 2 GHz (, up to 2.5 GHz, (6-core)
Processor Socket
LGA2011 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
16 GB (installed) / 96 GB (max) - DDR3 SDRAM - ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s); SATA (SATA 3Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
22 in 1
Graphics Controller
No graphics
Audio Output
Integrated
1GbE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
Intervideo WinDVD, Roxio Easy Media Creator, HP Support Assistant, HP Power Assistant, PDF Complete (Trial), HP Performance Advisor
Black, brushed aluminum
17.15 cm x 46.48 cm x 44.45 cm
15.5 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Recommended Use
Small business, corporate business
Product Form Factor
Mini tower - 4U
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Intel Xeon E5-2620
Clock Speed
2 GHz
Max Turbo Speed
2.5 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA2011 Socket
Chipset Type
Intel C602
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
16 GB / 96 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1333 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
8 (Total) / 4 (empty)
Unbuffered
Configuration Features
4 x 4 GB
RAM Supported
PC3-12800 - 96 GB registered - ECC , PC3-12800 - 48 GB unbuffered - ECC
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Native Command Queuing (NCQ)
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Channel Qty
2
RAID Level
RAID 0, RAID 1
Storage Controller (2nd)
SATA 3Gb/s
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
22 in 1 card reader
Supported Flash Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo, RS-MMC, microSD, SDHC Memory Card, microSDHC, Memory Stick PRO-HG Duo, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
Integrated
High Definition Audio
Input Device
Mouse
Mouse
Laser
USB
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel 82574L, Intel 82579LM
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 3 (total) / 2 (free) x internal 3.5" x 1/3H
Slots
2 (total) / 1 (free) x CPU , 8 (total) / 4 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height (x1 mode) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height
4 x USB 3.0 (2 front, 2 rear) , 5 x USB 2.0 (1 front, 4 rear) , 1 x PS/2 mouse , 1 x PS/2 keyboard , 2 x LAN (Gigabit Ethernet) , 1 x audio line-in , 2 x microphone (1 front, 1 rear) , 1 x audio line-out , 1 x headphones (1 in front) , 2 x FireWire (1 front, 1 rear)
System password, power-on password
ACPI 2.0, RoHS, WEEE
Power supply
Power Provided
800 Watt
80 PLUS Certification
80 PLUS
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
Software
17.15 cm
46.48 cm
44.45 cm
15.5 kg
5 °C
35 °C
8 - 85% (non-condensing)
