HP Z440 ZE3.5 E5 16GB 256GB W8.1/7P
Quicklinx: CN4MWS00 Mfr#: J9B65ET#ABU
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
Take your business to the next level of performance, expandability, and no compromise reliability in one complete package. Featuring a perfect mix of HP Z DNA in a performance workstation package with up to 8 discrete processor cores, up to 128 GB of RAM, and multiple storage and PCIe configuration options.
Get the job done fast
Cross items off your to-do list fast. Achieve massive computational performance with a single processor personal workstation delivering support for up to 8 cores of processing power. Add in powerful graphics and performance features like optional Thunderbolt 2, HP Z Turbo Drive, and HP Remote Graphics Software, and you get a world-class workstation experience that never slows you down.
Customize it to grow with you
When your job requires more, the HP Z440 Workstation, with its sleek 4U form factor, tool-less design, and built in handles make it simple to expand. Easily configure memory, storage, graphics, and more to suit your needs.
Position for the future
Protect your investment and make downtime a thing of the past. Get no-compromise reliability and a standard 3/3/3 limited warranty from the HP Z440 Workstation.
  • Primed to perform
    Achieve the performance you need with next generation Intel Xeon processors for up to 8 processor cores in one system.
  • Graphics pro
    Get serious about graphics and reach peak productivity with access to a breadth of AMD professional graphics from entry to high-end 3D.
  • See everything clearly
    Take productivity up a notch with the ability to do more thanks to NVIDIA professional graphics cards in 2D or 3D.
  • High-power ports
    Maximize your time and increase your capabilities with USB and SATA ports, plus lightning-fast data transfers using optional Thunderbolt 2 technology.
  • A chassis that meets any challenge
    A brand new tool-free chassis boasts low acoustics, single integrated Gb Ethernet and more.
  • Set a new performance curve for your HP Z440
    Reduce boot up, calculation, and graphics response and revolutionize how your HP Z440 handles large files with the HP Z Turbo Drive, a remarkably fast and innovative storage solution.
HP Workstation Z440 - MT - Xeon E5-1620V3 3.5 GHz - vPro - 16 GB - HDD 2 TB, SSD 256 GB - UK
Workstation - mini tower - power-on password, USB port control, audio ports control, network port control, Setup Password
Platform Technology
Intel vPro Platform
Height (Rack Units)
4U
1 x Intel Xeon E5-1620V3 / 3.5 GHz (, up to 3.6 GHz, (Quad-Core)
Processor Socket
LGA2011-v3 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
10 MB
Cache Per Processor
10 MB
RAM
16 GB (installed) / 128 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 2 TB - SATA 6Gb/s - 7200 rpm
Hard Drive (2nd)
SSD 256 GB - SATA 6Gb/s
Optical Storage
DVD SuperMulti
Graphics Controller
PCIe 3.0 x16 - AMD FirePro W5100
Video Memory
4 GB GDDR5 SDRAM
1GbE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Jack black
16.891 cm x 44.47 cm x 43.18 cm
11 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Mini tower - 4U
Built-in Devices
Solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Jack black
Processor / Chipset
CPU
Clock Speed
3.5 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
10 MB
Cache Per Processor
10 MB
RAM
Installed Size
16 GB / 128 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
8 (Total) / 4 (empty)
Registered
Configuration Features
4 x 4 GB
Hard Drive
HDD
1 x 2 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Hard Drive (2nd)
SSD
Interface Class
Serial ATA
1 x 256 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Interface Type
PCIe 3.0 x16
Graphics Processor
AMD FirePro W5100
Video Memory
4 GB GDDR5 SDRAM
Video Interfaces
DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Intel I218-LM
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 2 (total) / 0 (free) x internal 3.5"
Slots
8 (total) / 4 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, full-height , 2 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height
8 x USB 3.0 (4 front, 4 rear) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 4 x DisplayPort
Power-on password, USB port control, audio ports control, network port control, Setup Password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
Power supply
Power Provided
700 Watt
80 PLUS Certification
80 PLUS
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence - English
16.891 cm
44.47 cm
43.18 cm
11 kg
5 °C
35 °C
8 - 85% (non-condensing)
CN4M HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
CN4M HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £150.00
