Take your business to the next level of performance, expandability, and no compromise reliability in one complete package. Featuring a perfect mix of HP Z DNA in a performance workstation package with up to 8 discrete processor cores, up to 128 GB of RAM, and multiple storage and PCIe configuration options.
Get the job done fast
Cross items off your to-do list fast. Achieve massive computational performance with a single processor personal workstation delivering support for up to 8 cores of processing power. Add in powerful graphics and performance features like optional Thunderbolt 2, HP Z Turbo Drive, and HP Remote Graphics Software, and you get a world-class workstation experience that never slows you down. -
Customize it to grow with you
When your job requires more, the HP Z440 Workstation, with its sleek 4U form factor, tool-less design, and built in handles make it simple to expand. Easily configure memory, storage, graphics, and more to suit your needs. -
Position for the future
Protect your investment and make downtime a thing of the past. Get no-compromise reliability and a standard 3/3/3 limited warranty from the HP Z440 Workstation.
- HP Workstation Z440 - MT - Xeon E5-1650V3 3.5 GHz - vPro - 16 GB - SSD 256 GB - UK
- Workstation - mini tower
- Platform Technology
- Intel vPro Platform
- Height (Rack Units)
- 4U
- Localisation
- Processor
- 1 x Intel Xeon E5-1650V3 / 3.5 GHz (3.8 GHz) (6-core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 15 MB
- Cache Per Processor
- 15 MB
- RAM
- 16 GB (installed) / 128 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express 2.0 x4
- Optical Storage
- DVD SuperMulti
- Card Reader
- 15 in 1
- Graphics Controller
- No graphics
- Audio Output
- Integrated
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- Jack black
- 16.9 cm x 44.5 cm x 43.2 cm
- 11 kg
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Mini tower - 4U
- Built-in Devices
- Speaker, solenoid hood lock
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Jack black
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-1650V3 / 3.5 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 15 MB
- 15 MB
RAM
- Installed Size
- 16 GB / 128 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 8 (Total) / 6 (empty)
- Registered
- Configuration Features
- 2 x 8 GB
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Interface Type
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- 15 in 1 card reader
- Supported Flash Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card, Memory Stick Select, SDHC UHS-II Memory Card, SDXC UHS-II Memory Card, Memory Stick PRO-HG
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- Integrated
- High Definition Audio
Input Device
- Keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
- Integrated
- Interface (Bus) Type
- PCI Express 1.1 x1
- Ethernet Controller
- Intel I218-LM
- Data Link Protocol
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 2 (total) / 2 (free) x internal 3.5"
- Slots
- 8 (total) / 6 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 0 (free) x PCIe 2.0 x4 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height
- 8 x USB 3.0 (4 front, 4 rear) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) - RJ-45
- Included Accessories
- HP Business PC Security Lock Kit
- Power-on password, USB port control, audio ports control, network port control, Setup Password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Power supply
- Nominal Voltage
- Power Provided
- 700 Watt
- 80 PLUS Certification
- 80 PLUS
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence - English
- 16.9 cm
- 44.5 cm
- 43.2 cm
- 11 kg
- 5 °C
- 35 °C
- 8 - 85% (non-condensing)
