HP Z440 Workstation Intel Xeon E5-1620v3 8GB 2TB Windows 7 Professional 64-bit
Quicklinx: BD5DWS00 Mfr#: J9B35ET#ABU
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
Take your business to the next level of performance, expandability, and no compromise reliability in one complete package. Featuring a perfect mix of HP Z DNA in a performance workstation package with up to 8 discrete processor cores, up to 128 GB of RAM, and multiple storage and PCIe configuration options.
  • Primed to perform
    Achieve the performance you need with next generation Intel Xeon processors for up to 8 processor cores in one system.
  • Graphics pro
    Get serious about graphics and reach peak productivity with access to a breadth of AMD professional graphics from entry to high-end 3D.
  • See everything clearly
    Take productivity up a notch with the ability to do more thanks to NVIDIA professional graphics cards in 2D or 3D.
  • High-power ports
    Maximize your time and increase your capabilities with USB and SATA ports, plus lightning-fast data transfers using optional Thunderbolt 2 technology.
  • A chassis that meets any challenge
    A brand new tool-free chassis boasts low acoustics, single integrated Gb Ethernet and more.
  • Set a new performance curve for your HP Z440
    Reduce boot up, calculation, and graphics response and revolutionize how your HP Z440 handles large files with the HP Z Turbo Drive, a remarkably fast and innovative storage solution.
HP Workstation Z440 - MT - Xeon E5-1620V3 3.5 GHz - vPro - 8 GB - HDD 2 TB - UK
Workstation - mini tower - power-on password, USB port control, audio ports control, network port control, Setup Password
Platform Technology
Intel vPro Platform
Height (Rack Units)
4U
1 x Intel Xeon E5-1620V3 / 3.5 GHz (, up to 3.6 GHz, (Quad-Core)
Processor Socket
LGA2011-v3 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
10 MB
Cache Per Processor
10 MB
RAM
8 GB (installed) / 128 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 2 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
15 in 1
Graphics Controller
No graphics
Audio Output
Integrated
1GbE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Software Included
Cyberlink PowerDVD, HP Performance Advisor, CyberLink Media Suite, Foxit PhantomPDF Express, HP Remote Graphics Software 6
Jack black
16.9 cm x 44.5 cm x 43.2 cm
11 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Mini tower - 4U
Built-in Devices
Solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Jack black
Processor / Chipset
CPU
Clock Speed
3.5 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
10 MB
Cache Per Processor
10 MB
RAM
Installed Size
8 GB / 128 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
8 (Total) / 6 (empty)
Registered, quad channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
HDD
1 x 2 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
15 in 1 card reader
Supported Flash Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, SDHC Memory Card, Memory Stick PRO-HG Duo, SDXC Memory Card, Memory Stick Select, SDHC UHS-II Memory Card, SDXC UHS-II Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
Integrated
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
USB
Localization & Layout
Mouse
Laser
USB
Integrated
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Intel I218-LM
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x external 5.25" , 2 (total) / 1 (free) x internal 3.5"
Slots
8 (total) / 6 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height
8 x USB 3.0 (4 front, 4 rear) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet)
HP Business PC Security Lock Kit
Power-on password, USB port control, audio ports control, network port control, Setup Password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
Power supply
Power Provided
700 Watt
80 PLUS Certification
80 PLUS
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence - English
Software
16.9 cm
44.5 cm
43.2 cm
11 kg
5 °C
35 °C
8 - 85% (non-condensing)
