HP Z43 42.5" 3840x2160 5ms HDMI DisplayPort Mini DisplayPort USB-C LED Monitor
Quicklinx: F540WS00 Mfr#: 1AA85A4#ABU
£707.23 ex VAT
£848.67 inc VAT
Upgrade your impromptu meetings and collaborative brainstorming sessions with the 107.97 cm (42.51") diagonal HP Z43 4K UHD Display. Get started immediately with single USB-C cable connectivity to your devices.
  • Brilliant views
    Experience crisp, colorful picture quality and excellent content readability with more than 8 million pixels. The 4K, 3840 x 2160 resolution screen replaces a typical quad-display setup without the bezel interruptions of multi-screen tiling.
  • Go live in seconds
    Start your meetings fast with one-and-done device connectivity from a single USB-C cable that declutters your workspace, receives video and data, and can power your device up to 65W.
  • Create a content jam session
    Redefine onscreen collaboration when you pull content simultaneously from up to four PCs and broadcast together on the screen at the same time with Picture-by-Picture features.
HP Z43 - LED monitor - 4K - 43"
LED-backlit LCD monitor - 43"
Energy Class
Class G
Power Consumption (On mode)
54 W
USB 3.0 hub, USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Gamut
72% NTSC, 96% sRGB
Input Connectors
HDMI, DisplayPort, Mini DisplayPort, USB-C
Display Position Adjustments
Swivel, tilt
Screen Coating
Anti-glare
Voltage
Black Pearl
97.21 cm x 24 cm x 61.9 cm
16.95 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, UL, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CECP, EAC, CEL Grade 1, ISC, SEPA, low halogen, ICE
3-year warranty
Display Type
Energy Class
Class G
Diagonal Size
43"
Viewable Size
43"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Gamut
72% NTSC, 96% sRGB
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
47 - 63 Hz
Horizontal Refresh Rate
121.8 - 140 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
10000K
Picture by picture, HDCP, Mercury free, arsenic-free glass, Zero Bright Dot Warranty, Picture-in-Picture, 72% NTSC colour gamut
Black Pearl
97.21 cm x 24 cm x 61.9 cm - with stand
16.95 kg
DisplayPort (HDCP) , Mini DisplayPort , HDMI (HDCP) , USB-C upstream/DisplayPort Alt Mode , USB-C downstream , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
Swivel, tilt
Tilt Angle
-5/+10
Swivel Angle
20
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm
1 x USB-C to USB-A cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Backlight Life
30,000 hours
Input Voltage
54 W
54 kWh/1000h
Power Consumption (Typical)
95 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
Included Software
HP Display Assistant
Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
Dimensions & Weight Details
With stand - width: 97.21 cm - depth: 24 cm - height: 61.9 cm - weight: 16.95 kg , Without stand - width: 97.21 cm - depth: 12.28 cm - height: 56.59 cm - weight: 12.45 kg
Shipping Width
112 cm
Shipping Depth
70 cm
Shipping Height
36 cm
Shipping Weight
23.47 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
