HP Z43 42.5" 3840x2160 5ms HDMI DisplayPort Mini DisplayPort USB-C LED Monitor
Quicklinx: F540WS00 Mfr#: 1AA85A4#ABU
Diagonal Size: 42.5in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI, Mini DisplayPort, USB-C
Hurry, only 1 left in stock!
£666.97 ex VAT
£800.36 inc VAT
Upgrade your impromptu meetings and collaborative brainstorming sessions with the 107.97 cm (42.51") diagonal HP Z43 4K UHD Display. Get started immediately with single USB-C cable connectivity to your devices.
  • Brilliant views
    Experience crisp, colorful picture quality and excellent content readability with more than 8 million pixels. The 4K, 3840 x 2160 resolution screen replaces a typical quad-display setup without the bezel interruptions of multi-screen tiling.
  • Go live in seconds
    Start your meetings fast with one-and-done device connectivity from a single USB-C cable that declutters your workspace, receives video and data, and can power your device up to 65W.
  • Create a content jam session
    Redefine onscreen collaboration when you pull content simultaneously from up to four PCs and broadcast together on the screen at the same time with Picture-by-Picture features.
HP Z43 - LED monitor - 4K - 42.5"
LED-backlit LCD monitor - 42.5"
USB 3.0 hub, USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, DisplayPort, Mini DisplayPort, USB-C
Display Position Adjustments
Swivel, tilt
Screen Coating
Anti-glare
Black Pearl
97.21 cm x 24 cm x 61.9 cm
16.95 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, UL, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CECP, EAC, CEL Grade 1, ISC, SEPA, low halogen, ICE
3-year warranty
Display Type
Diagonal Size
42.5"
Viewable Size
42.5"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
47 - 63 Hz
Horizontal Refresh Rate
121.8 - 140 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
10000K
HDCP, 72% NTSC colour gamut, 96% sRGB colour gamut, Mercury free, arsenic-free glass, Zero Bright Dot Warranty, Picture-in-Picture, Picture-by-Picture
Black Pearl
97.21 cm x 24 cm x 61.9 cm - with stand
16.95 kg
DisplayPort (HDCP) , Mini DisplayPort , HDMI (HDCP) , USB-C upstream/DisplayPort , USB-C downstream , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
Swivel, tilt
Tilt Angle
-5/+10
Swivel Angle
20
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm
1 x USB-C to USB-A cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Backlight Life
30,000 hours
95 Watt
Included Software
HP Display Assistant
Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
Dimensions & Weight Details
With stand - width: 97.21 cm - depth: 24 cm - height: 61.9 cm - weight: 16.95 kg , Without stand - width: 97.21 cm - depth: 12.28 cm - height: 56.59 cm - weight: 12.45 kg
Shipping Width
112 cm
Shipping Depth
70 cm
Shipping Height
36 cm
Shipping Weight
23.47 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
HP Z43 42.5 Bundle deal on HP Z43 42.5" 3840x2160 5ms HDMI DisplayPort Mini DisplayPort USB-C LED Monitor
£766.14
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: USB-C
Brand: HP
Price Range Ex VAT: 500 - 750
