Upgrade your impromptu meetings and collaborative brainstorming sessions with the 107.97 cm (42.51") diagonal HP Z43 4K UHD Display. Get started immediately with single USB-C cable connectivity to your devices.
Brilliant views
Experience crisp, colorful picture quality and excellent content readability with more than 8 million pixels. The 4K, 3840 x 2160 resolution screen replaces a typical quad-display setup without the bezel interruptions of multi-screen tiling. -
Go live in seconds
Start your meetings fast with one-and-done device connectivity from a single USB-C cable that declutters your workspace, receives video and data, and can power your device up to 65W. -
Create a content jam session
Redefine onscreen collaboration when you pull content simultaneously from up to four PCs and broadcast together on the screen at the same time with Picture-by-Picture features.
- HP Z43 - LED monitor - 4K - 42.5"
- LED-backlit LCD monitor - 42.5"
- Energy Class
- Class G
- Power Consumption (On mode)
- 64 W
- USB 3.0 hub, USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.2451 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Gamut
- 72% NTSC, 96% sRGB
- Input Connectors
- HDMI, DisplayPort, Mini DisplayPort, USB-C
- Swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black Pearl
- 97.21 cm x 24 cm x 61.9 cm
- 16.95 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, UL, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CECP, EAC, CEL Grade 1, ISC, SEPA, low halogen, ICE
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Diagonal Size
- 42.5"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2451 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 47 - 63 Hz
- Horizontal Refresh Rate
- 121.8 - 140 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Colour Temperature
- 10000K
- Picture by picture, HDCP, Mercury free, arsenic-free glass, Zero Bright Dot Warranty, Picture-in-Picture, 72% NTSC colour gamut
- Black Pearl
- 97.21 cm x 24 cm x 61.9 cm - with stand
- 16.95 kg
- DisplayPort (HDCP) , Mini DisplayPort , HDMI (HDCP) , USB-C upstream/DisplayPort Alt Mode , USB-C downstream , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
- Swivel, tilt
- Tilt Angle
- -5/+10
- Swivel Angle
- 20
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm
- Cables Included
- 1 x USB-C to USB-A cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Input Voltage
- 64 W
- Power Consumption SDR (On mode)
- 64 kWh/1000h
- Power Consumption (Typical)
- 95 Watt
- Included Software
- HP Display Assistant
- OS Required
- Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
- Dimensions & Weight Details
- With stand - width: 97.21 cm - depth: 24 cm - height: 61.9 cm - weight: 16.95 kg , Without stand - width: 97.21 cm - depth: 12.28 cm - height: 56.59 cm - weight: 12.45 kg
- Shipping Width
- 112 cm
- Shipping Depth
- 70 cm
- Shipping Height
- 36 cm
- Shipping Weight
- 23.47 kg
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
HP B300 Mounting Bracket | In Stock | £32.48 |
