Brand
HP Z38c 37.5" 3840x1600 5ms HDMI DisplayPort USB-C Curved IPS LED Monitor
Quicklinx: F6W9WS00 Mfr#: Z4W65A4#ABU
Diagonal Size: 37.5in
Max Resolution: 3840 x 1600
Response Time: 5ms
Interfaces: DisplayPort, HDMI, USB-C
18 in stock
£944.44 ex VAT
£1,133.32 inc VAT
Standard delivery Delivered within 3-5 working days
Completely immerse yourself in the expansive elegance of the HP Z38c Curved Display. Form meets function with crisp, panoramic views so you can stay focused on your work.
  • HP's widest curved display
    Comfortably view your work on the large 95.25 cm (37.5") diagonal curve. Feel the immersion with a 2300 mm radius that fits your natural field of vision. It's the sweet spot for day-in, day-out use.
  • One large screen
    Give big ideas room to breathe inside a wide 21:9 aspect ratio. See your entire project without the distracting bezels in the middle of a dual display setup. One large viewing area keeps you more productive when working in multiple applications.
  • Your vision in perfect detail
    See every facet of your creation in crystal-clear 4K-wide, 3840x1600 resolution. With optimized pixel density your icons and text are the ideal size so you can spend less time panning and zooming and more time creating.
HP Z38c - LED monitor - curved - 37.5"
LED-backlit LCD monitor - 37.5"
Energy Class
Class G
Energy Consumption per Year
93 kWh
Power Consumption (On mode)
64 W
Curved Screen
USB-C hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
UWQHD+ 3840 x 1600 at 60 Hz
Pixel Pitch
0.229 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
14 ms (grey-to-grey); 5 ms (grey-to-grey with overdrive)
Colour Support
1.07 billion colours
Colour Gamut
98%
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
89.55 cm x 24.8 cm x 55.87 cm
13.8 kg
English / United Kingdom
Plug and Play, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, KC, CECP, EAC, ISC, MSIP, SEPA, BIS, CoC
Display Type
Energy Class
Class G
93 kWh
Diagonal Size
37.5"
Curved Screen
Yes (2300R)
Built-in Devices
USB-C hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.229 mm
Pixel Per Inch
110.93
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
98%
Response Time
Vertical Refresh Rate
24 - 76 Hz
Horizontal Refresh Rate
27 - 130 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Micro Edge
89.55 cm x 24.8 cm x 55.87 cm - with stand
13.8 kg
HDMI (HDCP) , USB-C (HDCP) , DisplayPort (HDCP) , 2 x USB downstream , 3 x USB 3.0 downstream , Audio line-out , USB downstream , USB-C upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x DisplayPort cable , 1 x HDMI cable , 1 x USB-C cable
Backlight Life
30,000 hours
Input Voltage
64 W
64 kWh/1000h
Power Consumption (Typical)
80 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 89.55 cm - depth: 24.8 cm - height: 55.87 cm - weight: 13.8 kg , Without stand - width: 89.55 cm - depth: 10.42 cm - height: 39.95 cm - weight: 9.8 kg
5 °C
35 °C
20 - 80% (non-condensing)
F6W9 HP B300 Mounting Bracket In Stock £32.48
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: F6W9 045743
Condition: Customer return - item has been used but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £841.50
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Response Time: 5ms
Interfaces: HDMI
Interfaces: USB-C
Brand: HP
Price Range Ex VAT: £750 - £1000
Stock Status: In stock
Stock Status: Used Stock
