Completely immerse yourself in the expansive elegance of the HP Z38c Curved Display. Form meets function with crisp, panoramic views so you can stay focused on your work.
HP's widest curved display
Comfortably view your work on the large 95.25 cm (37.5") diagonal curve. Feel the immersion with a 2300 mm radius that fits your natural field of vision. It's the sweet spot for day-in, day-out use. -
One large screen
Give big ideas room to breathe inside a wide 21:9 aspect ratio. See your entire project without the distracting bezels in the middle of a dual display setup. One large viewing area keeps you more productive when working in multiple applications. -
Your vision in perfect detail
See every facet of your creation in crystal-clear 4K-wide, 3840x1600 resolution. With optimized pixel density your icons and text are the ideal size so you can spend less time panning and zooming and more time creating.
- HP Z38c - LED monitor - curved - 37.5"
- LED-backlit LCD monitor - 37.5"
- Energy Class
- Class G
- Energy Consumption per Year
- 93 kWh
- Power Consumption (On mode)
- 64 W
- Curved Screen
- USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- UWQHD+ 3840 x 1600 at 60 Hz
- Pixel Pitch
- 0.229 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 14 ms (grey-to-grey), 5 ms (grey-to-grey with overdrive)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 98%
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 89.55 cm x 24.8 cm x 55.87 cm
- 13.8 kg
- Localisation
- English / United Kingdom
- Plug and Play, VCCI, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, KC, CECP, EAC, ISC, MSIP, SEPA, BIS, CoC
- Display Type
- Energy Class
- Class G
- 93 kWh
- Diagonal Size
- 37.5"
- Curved Screen
- Yes (2300R)
- Built-in Devices
- USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.229 mm
- Pixel Per Inch
- 110.93
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 98%
- Response Time
- Vertical Refresh Rate
- 24 - 76 Hz
- Horizontal Refresh Rate
- 27 - 130 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, Micro Edge
- Black
- 89.55 cm x 24.8 cm x 55.87 cm - with stand
- 13.8 kg
- HDMI (HDCP) , USB-C (HDCP) , DisplayPort (HDCP) , 2 x USB downstream , 3 x USB 3.0 downstream , Audio line-out , USB downstream , USB-C upstream
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x DisplayPort cable , 1 x HDMI cable , 1 x USB-C cable
- Backlight Life
- 30,000 hours
- Localisation
- Input Voltage
- 64 W
- Power Consumption SDR (On mode)
- 64 kWh/1000h
- Power Consumption (Typical)
- 80 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 89.55 cm - depth: 24.8 cm - height: 55.87 cm - weight: 13.8 kg , Without stand - width: 89.55 cm - depth: 10.42 cm - height: 39.95 cm - weight: 9.8 kg
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
HP B300 Mounting Bracket | In Stock | £32.48 |
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
F6W9 045743 Condition: Customer return - item has been used but is in excellent condition |
£466.36 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
