Experience extraordinary, precise color and see more of your projects at one time on a display with stunning 4K resolution.
Incredible clarity for maximum productivity
Optimize your workflows with a large, 4K display. View more lines of code, bigger spreadsheets, and vibrant colors, all with minimal toggling and scrolling. -
One powerful connection
Work fast and clutter-free with USB-C connectivity that not only receives video and data from your device, but also delivers up to 65W of power-with just one cable. -
Reliable visual solution
Perfect your designs, projects, and documents on a display built to meet your demands. All HP Z Displays are rigorously tested and backed by an exclusive HP Zero Bright Dot Guarantee that replaces the screen if even one bright sub-pixel fails.
- HP Z32 - LED monitor - 4K - 31.5"
- LED-backlit LCD monitor - 31.5"
- Energy Class
- Class G
- Energy Consumption per Year
- 66 kWh
- Power Consumption (On mode)
- 33 W
- USB 3.0/USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.181 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1300:1 / 5000000:1 (dynamic)
- Response Time
- 14 ms (grey-to-grey)
- Colour Gamut
- 100% BT.709, 99% sRGB
- Input Connectors
- HDMI, DisplayPort, Mini DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 71.45 cm x 24.8 cm x 56.44 cm
- 12.16 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen, ICE
- 5-year warranty
- Display Type
- Energy Class
- Class G
- 66 kWh
- Diagonal Size
- 31.5"
- Built-in Devices
- USB 3.0/USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.181 mm
- Pixel Per Inch
- 140
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 29 - 60 Hz
- Horizontal Refresh Rate
- 28 - 135 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- HDCP, anti-glare, Mercury free, arsenic-free glass, 99% sRGB colour gamut
- Black
- 71.45 cm x 24.8 cm x 56.44 cm - with stand
- 12.16 kg
- DisplayPort , Mini DisplayPort , HDMI , Audio line-out , 3 x USB 3.0 downstream , USB-C upstream , USB-C downstream
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 33 W
- Power Consumption SDR (On mode)
- 33 kWh/1000h
- Power Consumption (Typical)
- 70 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 71.45 cm - depth: 24.8 cm - height: 56.44 cm - weight: 12.16 kg , Without stand - width: 71.45 cm - depth: 4.45 cm - height: 41.09 cm - weight: 7.59 kg
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 5 years - on-site - response time: next business day
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
