Product
HP Z30i 30" 2560x1600 VGA DVI-D DisplayPort IPS Monitor
Quicklinx: 98QKWS00 Mfr#: D7P94AT#ABU
Diagonal Size: 30in
Max Resolution: 2560 x 1600
Response Time: 8ms
Speakers: None
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£1,122.46 ex VAT
£1,346.95 inc VAT
Get outstanding image accuracy, exceptional adjustability, and mission-critical reliability optimized for commercial environments. Built with IPS Gen 2 panels, the HP Z30i 76,2 cm (30') IPS Display delivers power savings over first-generation IPS technology and extra-wide viewing angles that foster collaboration.
  • Say hello to your new power-smart IPS Gen 2 team player
    Lower your power consumption and get 100% coverage of sRGB color spaces and 99% coverage of Adobe RGB color spaces from IPS Gen 2 panels.Speed team reviews and collaborative decision-making with extra-wide viewing angles that give everyone the same great view.See all the stunning details on a 30-inch diagonal display with narrow bezels and an ultra-high resolution of 2560 x 1600 that provides 4.1M pixels of ultimate visual power.Experience crisp, clear presentation from 350 cd/m2 brightness, 1000:1 contrast ratio, 5M:1 dynamic contrast ratio, and 8 ms response time.Enhance the dark regions of your onscreen images and see the smallest details even better with integrated Black Stretch technology.
  • Designed-in comfort
    Find your most comfortable position with an HP-exclusive 4-way adjustable stand and an integrated HP QR2 Quick Release than enables VESA mounting.
  • Get connected
    Enjoy future-ready and legacy connectivity from a range of inputs that include DisplayPort 1.2, DVI, VGA, HDMI 1.4, audio output for an HP Speaker Bar, and four USB 3.0 ports with speeds up to 10x faster than USB 2.0.
  • Keep it together
    Get organized with the integrated cable management clip. Create a clean, compact all-in-one with the optional HP Thin Client Mount Kit. The HP QR2 Quick Release is integrated into the display to enable quick set up, and it's VESA mountable.
  • Meet your monitor's new best friend
    Customize your workspace with resizable screen partitions. Work in documents, spreadsheets, and email in separate regions of the screen-at the same time-with HP Display Assistant software.View open applications on all of your connected displays with the expanded toolbar. Help deter theft with a user-designated PIN that deactivates the monitor if it's disconnected from a PC without approval.
HP Z30i - LED monitor - 30"
LED-backlit LCD monitor - 30"
Energy Class
Class C
Energy Consumption per Year
97 kWh
Power Consumption (On mode)
66 W
USB 3.0 hub
Panel Type
IPS2
Aspect Ratio
16:10
Native Resolution
2560 x 1600 at 60 Hz
Pixel Pitch
0.25 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Input Connectors
HDMI, DVI-I, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
69.03 cm x 26.64 cm x 60.1 cm
9.96 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, TCO Certified Edge, KC, CECP, EPA, CEL Grade 1
5 years warranty
Display Type
Energy Class
Class C
97 kWh
66 W
Diagonal Size
30"
Viewable Size
29.83"
Built-in Devices
USB 3.0 hub
Panel Type
IPS2
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.25 mm
Brightness
350 cd/m²
Contrast Ratio
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
60 - 70 Hz
Horizontal Refresh Rate
31 - 80 KHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
Controls & Adjustments
Brightness, contrast
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
69.03 cm x 26.64 cm x 60.1 cm - with stand
9.96 kg
DisplayPort (HDCP) , DVI-D (HDCP) , VGA (HD-15) , HDMI (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
45
Rotation Angle
90
Height Adjustment
120 mm
1 x USB cable , 1 x DisplayPort cable
Mounting Kit
Included
Backlight Life
30,000 hours
Power Supply
Internal
85 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
0.34 Watt
Included Software
Dimensions & Weight Details
With stand - width: 69.03 cm - depth: 26.64 cm - height: 60.1 cm - weight: 9.96 kg , Without stand - width: 69.03 cm - depth: 6.63 cm - height: 44.98 cm - weight: 7.56 kg
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
HP Z30i 30 Bundle deal on HP Z30i 30" 2560x1600 VGA DVI-D DisplayPort IPS Monitor
£1,219.45
Diagonal Size: 30in
Response Time: 8ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 1000 - 1500
