Redefine life like image presentation with the HP Z27q 68,6 cm (27') IPS 5K Display, which delivers more screen real estate and color clarity with an astounding 5K resolution.
Out-of-the-box color calibration
Enjoy accurate color calibration for sRGB, Adobe RGB, and BT.709-the same color space as Blu-ray media-from the very first time you power on. -
Extraordinary color
Get smoother gradations, clearer images, and unbelievably rich color presentation on all your projects from the professional grade, 10-bit color quality and up to 1.07 billion colors.
- HP Z27q - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 5K Ultra HD (2880p) 5120 x 2880 at 60 Hz
- Brightness
- 300 cd/m²
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% Adobe RGB
- Input Connectors
- 2xDisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V
- 63.43 cm x 21.71 cm x 38.03 cm
- 7.42 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play
- Display Type
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Per Inch
- 218
- Brightness
- 300 cd/m²
- Colour Support
- Colour Gamut
- 99% Adobe RGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP
- 63.43 cm x 21.71 cm x 38.03 cm - with stand
- 7.42 kg
- 2 x DisplayPort (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 360
- Plug and Play
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 125 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 63.43 cm - depth: 21.71 cm - height: 38.03 cm - weight: 7.42 kg , Width: 63.43 cm - depth: 6.2 cm - height: 38.034 cm
Sustainability Information
- ENERGY STAR Certified
