HP Z27q 27" 5120x2880 14ms DisplayPort 5K IPS LED Monitor
Quicklinx: BKYMWS00 Mfr#: J3G14AT#ABU
Redefine life like image presentation with the HP Z27q 68,6 cm (27') IPS 5K Display, which delivers more screen real estate and color clarity with an astounding 5K resolution.
  • Out-of-the-box color calibration
    Enjoy accurate color calibration for sRGB, Adobe RGB, and BT.709-the same color space as Blu-ray media-from the very first time you power on.
  • Extraordinary color
    Get smoother gradations, clearer images, and unbelievably rich color presentation on all your projects from the professional grade, 10-bit color quality and up to 1.07 billion colors.
HP Z27q - LED monitor - 27"
LED-backlit LCD monitor - 27"
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
5K Ultra HD (2880p) 5120 x 2880 at 60 Hz
Brightness
300 cd/m²
Response Time
8 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
99% Adobe RGB
Input Connectors
2xDisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 120/230 V
63.43 cm x 21.71 cm x 38.03 cm
7.42 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play
Display Type
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Per Inch
218
Brightness
300 cd/m²
Colour Support
Colour Gamut
99% Adobe RGB
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP
63.43 cm x 21.71 cm x 38.03 cm - with stand
7.42 kg
2 x DisplayPort (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+22
Swivel Angle
360
Plug and Play
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
Power Consumption (Typical)
125 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 63.43 cm - depth: 21.71 cm - height: 38.03 cm - weight: 7.42 kg , Width: 63.43 cm - depth: 6.2 cm - height: 38.034 cm
Sustainability Information
ENERGY STAR Certified
