HP Z27N G2 27" 2560x1440 5.3ms DisplayPort HDMI DVI-D USB-C LED Monitor
Quicklinx: DZRJWS00 Mfr#: 1JS10AT#ABU
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5.3ms
Interfaces: DisplayPort, DVI, HDMI, USB-C
More than 50 in stock
£276.67 ex VAT
£332.00 inc VAT
Be a productive powerhouse with the sleek QHD HP Z27n G2 68.58 cm (27") Display. This virtually seamless display is factory-tested for reliability and longevity with integrated color calibration, uninterrupted multi-screen tiling, and expansive device connections, including USB-C .
  • Multi-screen productivity with no disruptions
    Streamline multi-tasking on multiple displays with a 3-sided micro-edge bezel, and daisy chain up to 2 displays per workstation with DisplayPort . Get stunning visuals from 2560 x 1440 resolution, 16:9 aspect ratio, and over 3 million pixels.
  • Out-of-this-world color right out of the box
    Consistent, accurate color between displays and from project to project is easier than ever with factory color calibration from the very first time you power on.
  • Quality from the start
    We rigorously test each HP Z Display to help ensure it's a reliable, long-life visual solution, and back it up with the HP Zero Bright Dot Guarantee, HP's most stringent pixel policy, which replaces the screen if even one bright sub-pixel fails.
  • Future-ready connectivity
    Keep it clean with a single USB-C cable video and data connection that's ready for future generations of HP Workstations. VGA, HDMI, and DisplayPort are multi-generation compatible, and a three-port USB 3.0 hub supports convenient device connectivity.
HP Z27n G2 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
53 kWh
Power Consumption (On mode)
36 W
USB 3.0/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
14 ms (default), 5.3 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DisplayPort, HDMI, DVI-D, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Black Pearl
61.3 cm x 21.4 cm x 50.9 cm
8 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, E-Standby, KC, ERP, CEL Grade 1, ISC, RCM, MSIP, CEL Grade 2, SEPA, CoC, CU
5-year warranty
Display Type
Energy Class
Class B
53 kWh
36 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
111.89
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
24 - 75 Hz
Horizontal Refresh Rate
27 - 112 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 99% sRGB colour gamut, Low Blue Light Mode, Flicker Free technology, daisy chain compatible, Factory Calibration, arsenic-free glass, Micro Edge
Black Pearl
61.3 cm x 21.4 cm x 50.9 cm - with stand
8 kg
DisplayPort (HDCP) , DisplayPort output (HDCP) , HDMI (HDCP) , DVI-D , 3 x USB 3.0 downstream with Power Delivery , USB-C 3.1 downstream with Power Delivery , USB-C 3.1 Gen 1 upstream/DisplayPort with Power Delivery , Headphones
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
VESA bracket
1 x DisplayPort cable - 1.8 m , 1 x USB-C 3.1 cable - USB Type C to A - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
48 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities, HP Display Assistant
Dimensions & Weight Details
With stand - width: 61.3 cm - depth: 21.4 cm - height: 50.9 cm - weight: 8 kg , Without stand - width: 61.3 cm - depth: 4.71 cm - height: 36.4 cm - weight: 5.2 kg
Shipping Width
70.7 cm
Shipping Depth
44.6 cm
Shipping Height
28.2 cm
Shipping Weight
11 kg
ENERGY STAR Certified
TCO Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
HP Z27N G2 27 Bundle deal on HP Z27N G2 27" 2560x1440 5.3ms DisplayPort HDMI DVI-D USB-C LED Monitor
£375.84
Diagonal Size: 27in
Interfaces: DVI
Interfaces: HDMI
Interfaces: USB-C
Brand: HP
Price Range Ex VAT: 150 - 300
