HP Z27n 27" 2560x1440 14ms DVI HDMI DisplayPort QHD IPS LED Monitor
Quicklinx: BKYRWS00 Mfr#: K7C09A4#ABU
Enable a virtually borderless panorama of multiple displays with the HP Z27n narrow bezel IPS display, which has an edge-to-edge screen for maximum quad HD impact, out-of-the-box factory color calibration, and flexible connectivity for all of your devices.
  • Edge-to-edge experience
    Get Quad HD 2560 x 1440 resolution visuals from a three-sided borderless design that reveals more of the 68,6 cm (27") diagonal screen and enables uninterrupted views of multiple displays.
  • Color calibration at the ready
    Enjoy reliable color accuracy across all of your projects with a factory-calibrated 99% sRGB color gamut from the very first time you turn on your display.
  • Create a total workspace
    Connect to your everyday devices with integrated HDMI, mDP, DP, MHL, DVI, and a USB 3.0 hub with a fast-charging port. The DisplayPort output allows you to daisy chain up to two displays with just one PC or workstation connection.
HP Z27n - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
55 kWh
Power Consumption (On mode)
37 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
14 ms (grey-to-grey), 8 ms (overdrive)
Colour Support
16.7 million colours
Input Connectors
DVI-D, DisplayPort, Mini DisplayPort, HDMI (MHL)
Display Position Adjustments
Screen Coating
Anti-glare
61.43 cm x 21.82 cm x 53.37 cm
7.66 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
TCO Certified ENERGY STAR Qualified
Plug and Play, UL, TUV GS, VCCI, C-Tick, BSMI, TUV S, WHQL, CB, CCC, TUV Ergo, FCC, KC, CECP, CEL Grade 2, SEPA
5-year warranty
Display Type
Energy Class
Class B
55 kWh
37 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
108.8
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 90 kHz
Video Bandwidth
250 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Colour balance, input select, luminance
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, edge-to-edge glass, 99% sRGB colour gamut
61.43 cm x 21.82 cm x 53.37 cm - with stand
7.66 kg
MHL / HDMI (HDCP) , DVI-D (dual link) (HDCP) , Mini DisplayPort (HDCP) , DisplayPort (HDCP) , DisplayPort output (HDCP) , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
Tilt Angle
-5/+22
Swivel Angle
45
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), HP Quick Release, detachable stand, 1 USB 3.0 fast charging port, VESA 100 x 100 mm
1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
83 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 61.43 cm - depth: 21.82 cm - height: 53.37 cm - weight: 7.66 kg , Without stand - width: 61.43 cm - depth: 5.39 cm - height: 36.41 cm - weight: 5.1 kg
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
