HP Z27 27" 3840x2160 8ms HDMI DP Mini DP USB-C LED Monitor
Quicklinx: F53TWS00 Mfr#: 2TB68AT#ABU
Diagonal Size: 27in
Max Resolution: 3840 x 2160
Response Time: 8ms
Speakers: None
Interfaces: DisplayPort, HDMI, Mini DisplayPort, USB-C
30 in stock
£476.42 ex VAT
£571.70 inc VAT
Experience extraordinary, precise color and see more of your projects at one time on a display with stunning 4K resolution.
  • Incredible clarity for maximum productivity
    Optimize your workflows with a large, 4K display. View more lines of code, bigger spreadsheets, and vibrant colors, all with minimal toggling and scrolling.
  • One powerful connection
    Work fast and clutter-free with USB-C connectivity that not only receives video and data from your device, but also delivers up to 65W of power-with just one cable.
  • Reliable visual solution
    Perfect your designs, projects, and documents on a display built to meet your demands. All HP Z Displays are rigorously tested and backed by an exclusive HP Zero Bright Dot Guarantee that replaces the screen if even one bright sub-pixel fails.
HP Z27 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
62 kWh
Power Consumption (On mode)
42 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1300:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
1024 grey levels (10-bit)
Input Connectors
HDMI, DisplayPort, Mini DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Black Pearl
61.41 cm x 23 cm x 50.98 cm
9.38 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 7, TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, UL, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, low halogen, ICE
3-year warranty
Display Type
Energy Class
Class B
62 kWh
42 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Pixel Per Inch
163
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Frame Rate Control (FRC), 99% sRGB colour gamut, Mercury free, Color Calibrated, Micro Edge, arsenic free, 100% BT.709 colour gamut, Picture-in-Picture, Picture-by-Picture
Black Pearl
61.41 cm x 23 cm x 50.98 cm - with stand
9.38 kg
HDMI (HDCP) , DisplayPort (HDCP) , USB-C upstream , Mini DisplayPort (HDCP) , USB-C downstream , Audio line-out , 3 x USB downstream (Type A)
Mechanical
Tilt Angle
-5/+23
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x USB-C to USB-A cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
70 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 61.41 cm - depth: 23 cm - height: 50.98 cm - weight: 11.61 kg , Without stand - width: 61.41 cm - depth: 5.45 cm - height: 36.54 cm - weight: 6.21 kg
Shipping Width
72.4 cm
Shipping Depth
32.2 cm
Shipping Height
48 cm
ENERGY STAR Certified
ENERGY STAR Version
7.0
TCO Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
HP Z27 27 Bundle deal on HP Z27 27" 3840x2160 8ms HDMI DP Mini DP USB-C LED Monitor
£575.59
Diagonal Size: 27in
Response Time: 8ms
Speakers: None
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: USB-C
Brand: HP
Price Range Ex VAT: 300 - 500
