HP Z27 27" 3840x2160 8ms HDMI DP Mini DP USB-C LED Monitor
Quicklinx: F53TWS00 Mfr#: 2TB68AT#ABU
Diagonal Size: 27in
Max Resolution: 3840 x 2160
Response Time: 8ms
Speakers: None
Interfaces: DisplayPort, HDMI, Mini DisplayPort, USB-C
£431.61 ex VAT
£517.93 inc VAT
Experience extraordinary, precise color and see more of your projects at one time on a display with stunning 4K resolution.
  • Incredible clarity for maximum productivity
    Optimize your workflows with a large, 4K display. View more lines of code, bigger spreadsheets, and vibrant colors, all with minimal toggling and scrolling.
  • One powerful connection
    Work fast and clutter-free with USB-C connectivity that not only receives video and data from your device, but also delivers up to 65W of power-with just one cable.
  • Reliable visual solution
    Perfect your designs, projects, and documents on a display built to meet your demands. All HP Z Displays are rigorously tested and backed by an exclusive HP Zero Bright Dot Guarantee that replaces the screen if even one bright sub-pixel fails.
HP Z27 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
62 kWh
Power Consumption (On mode)
42 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1300:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
1024 grey levels (10-bit)
Input Connectors
HDMI, DisplayPort, Mini DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Black Pearl
61.41 cm x 23 cm x 50.98 cm
9.38 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, UL, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, low halogen, ICE
3-year warranty
Display Type
Energy Class
Class B
62 kWh
42 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Pixel Per Inch
163
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Frame Rate Control (FRC), 99% sRGB colour gamut, Mercury free, Color Calibrated, Micro Edge, arsenic free, 100% BT.709 colour gamut, Picture-in-Picture, Picture-by-Picture
Black Pearl
61.41 cm x 23 cm x 50.98 cm - with stand
9.38 kg
HDMI (HDCP) , DisplayPort (HDCP) , USB-C upstream , Mini DisplayPort (HDCP) , USB-C downstream , Audio line-out , 3 x USB downstream (Type A)
Mechanical
Tilt Angle
-5/+23
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x USB-C to USB-A cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
70 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 61.41 cm - depth: 23 cm - height: 50.98 cm - weight: 11.61 kg , Without stand - width: 61.41 cm - depth: 5.45 cm - height: 36.54 cm - weight: 6.21 kg
Shipping Width
72.4 cm
Shipping Depth
32.2 cm
Shipping Height
48 cm
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.0
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Diagonal Size: 27in
Response Time: 8ms
Speakers: None
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: USB-C
Brand: HP
Price Range Ex VAT: 300 - 500
