HP Z24s 23.8" 3840x2160 14ms HDMI MHL DisplayPort UHD IPS LED Monitor
Quicklinx: BKYGWS00 Mfr#: J2W50AT#ABU
Experience ultra high-definition /4K image presentation and factory-calibrated color accuracy out of the box with the HP Z24s 60,45 cm (23.8") IPS UHD Display, which also delivers flexible connectivity and comfort features-all at HP's most affordable HP Z Display price point.
  • The display that delivers what you demand
    Get massive 3840 x 2160 resolution, 185 ppi, and sRGB color gamut for your demanding digital workflows. Wide viewing angles and a 60,45 (23.8") diagonal screen help ensure easy line of sight for one or many viewers.
  • Limitless connectivity
    Connect your display to a workstation, PC, and range of digital video devices with DisplayPort, mini-DisplayPort, HDMI, and four USB 3.0 ports. Use the two side-located USB ports for easy access to your most-used peripherals.
  • UHD for every device
    Instantly mirror your smart phone or tablet content to the large screen through an easy MHL connection that also keeps your devices charged and ready to go.
  • Pixels for days
    Get expansive views of your projects, documents, and media with 8MP-4x that of a Full HD display. View your mobile device and PC feeds side by side in picture-in-picture and picture-by-picture modes.
HP Z24s - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class C
Energy Consumption per Year
64 kWh
Power Consumption (On mode)
44 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
Pixel Pitch
0.137 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
14 ms (grey-to-grey)
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort, MHL
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
55.61 cm x 21.02 cm x 52.68 cm
6.46 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, KC, EPA, EAC, CEL Grade 1, ISC
3-year warranty
Display Type
Energy Class
Class C
64 kWh
Diagonal Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.137 mm
Pixel Per Inch
185.4
Brightness
300 cd/m²
Contrast Ratio
Response Time
Vertical Refresh Rate
24 - 60 Hz
Horizontal Refresh Rate
24 - 135 kHz
Video Bandwidth
600 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, input select
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP
55.61 cm x 21.02 cm x 52.68 cm - with stand
6.46 kg
HDMI (HDCP) , MHL / HDMI (HDCP) , DisplayPort (HDCP) , Mini DisplayPort , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x DisplayPort cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
44 W
Power Consumption (Typical)
88 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 55.61 cm - depth: 21.02 cm - height: 52.68 cm - weight: 6.46 kg , Without stand - width: 55.61 cm - depth: 6.97 cm - height: 33.53 cm - weight: 4.3 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
