HP Z24nq Narrow Bezel LED 23.8" Monitor 2560x1440 HD Black
Quicklinx: C7XMWS00 Mfr#: L1K59AT#ABU
Enjoy quad HD visuals on the HP Z24nq Narrow Bezel IPS Display,which has an edge-to-edge 60,45 cm (23.8") diagonal screen for easy tiling of multiple displays,plus out-of-the-box color calibration and flexible connectivity for all of your devices.
  • Outstanding visuals
    Experience even more of the 60,45 cm (23.8") diagonal 2560 x 1440 resolution screen with a three-sided borderless design that enables uninterrupted views of multiple displays.
  • Accurate color out of the box
    Get factory-calibrated RGB color for reliable color accuracy across all of your projects from the very first time you turn on your display.
  • Connect efficiently
    Connect to your everyday devices with integrated HDMI, mDP, DP, MHL, DVI, and a USB 3.0 hub with a fast-charging port. A DisplayPort output allows you to daisy chain up to two displays with just one PC or workstation connection.
HP Z24nq - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class B
Energy Consumption per Year
41 kWh
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.206 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 500000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xDisplayPort, DVI-D, Mini DisplayPort, HDMI (MHL)
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100/240 V (50/60 Hz)
54.06 cm x 21.01 cm x 5.09 cm
5.5 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, UL, TUV GS, VCCI, C-Tick, BSMI, TUV S, CB, CCC, TUV Ergo, FCC, KC, CECP, CEL, SEPA
3-year warranty
Display Type
Energy Class
Class B
41 kWh
Diagonal Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.206 mm
Pixel Per Inch
123.4
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 90 kHz
Video Bandwidth
250 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Colour temperature, luminance
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Mercury free, arsenic-free glass
54.06 cm x 21.01 cm x 5.09 cm - with stand
5.5 kg
DVI-D (dual link) (HDCP) , MHL / HDMI (HDCP) , DisplayPort (HDCP) , DisplayPort output , Mini DisplayPort (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
Tilt Angle
-2/+22
Swivel Angle
45
Rotation Angle
90
Height Adjustment
130 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HP Quick Release 2
1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
48 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
HP Display Assistant
Dimensions & Weight Details
Without stand - width: 54.06 cm - depth: 5.04 cm - height: 32.34 cm - weight: 3.6 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
