Enjoy quad HD visuals on the HP Z24nq Narrow Bezel IPS Display,which has an edge-to-edge 60,45 cm (23.8") diagonal screen for easy tiling of multiple displays,plus out-of-the-box color calibration and flexible connectivity for all of your devices.
Outstanding visuals
Experience even more of the 60,45 cm (23.8") diagonal 2560 x 1440 resolution screen with a three-sided borderless design that enables uninterrupted views of multiple displays. -
Accurate color out of the box
Get factory-calibrated RGB color for reliable color accuracy across all of your projects from the very first time you turn on your display. -
Connect efficiently
Connect to your everyday devices with integrated HDMI, mDP, DP, MHL, DVI, and a USB 3.0 hub with a fast-charging port. A DisplayPort output allows you to daisy chain up to two displays with just one PC or workstation connection.
- HP Z24nq - LED monitor - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class B
- Energy Consumption per Year
- 41 kWh
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.206 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 500000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xDisplayPort, DVI-D, Mini DisplayPort, HDMI (MHL)
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100/240 V (50/60 Hz)
- Black
- 54.06 cm x 21.01 cm x 5.09 cm
- 5.5 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, UL, TUV GS, VCCI, C-Tick, BSMI, TUV S, CB, CCC, TUV Ergo, FCC, KC, CECP, CEL, SEPA
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 41 kWh
- Diagonal Size
- 23.8"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.206 mm
- Pixel Per Inch
- 123.4
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Video Bandwidth
- 250 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Colour temperature, luminance
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, Mercury free, arsenic-free glass
- Black
- 54.06 cm x 21.01 cm x 5.09 cm - with stand
- 5.5 kg
- DVI-D (dual link) (HDCP) , MHL / HDMI (HDCP) , DisplayPort (HDCP) , DisplayPort output , Mini DisplayPort (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
- Tilt Angle
- -2/+22
- Swivel Angle
- 45
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support, HP Quick Release 2
- Cables Included
- 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 48 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 54.06 cm - depth: 5.04 cm - height: 32.34 cm - weight: 3.6 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
