HP Z24i G2 24" 1920x1200 5ms HDMI VGA DisplayPort LED Monitor
Quicklinx: DZRHWS00 Mfr#: 1JS08AT#ABU
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 5ms
Interfaces: DisplayPort, HDMI, VGA (HD-15)
38 in stock
£267.30 ex VAT
£320.76 inc VAT
Be a productive powerhouse with the sleek HP Z24i G2 60.96 cm (24") Display. This virtually seamless WUXGA display is factory-tested for reliability and longevity with integrated color calibration, uninterrupted multi-screen tiling, and expansive device connections.
  • Streamline productivity with screens for every project
    Multi-task without disruptions across multiple displays with a 3-sided micro-edge bezel on each screen. Get stunning visuals from the 1900 x 1200 resolution, 16:10 aspect ratio, 60.96 cm (24") diagonal IPS screen and over 2 million pixels.
  • Out-of-this-world color right out of the box
    Consistent, accurate color between displays and from project to project is easier than ever with factory color calibration from the very first time you power on.
  • Quality from the start
    We rigorously test each HP Z Display to help ensure it's a reliable, long-life visual solution, and back it up with the HP Zero Bright Dot Guarantee, HP's most stringent pixel policy, which replaces the screen if even one bright sub-pixel fails.
  • Big ideas for small spaces
    Make the most of your available workspace by mounting powerful machines like the HP Z2 Mini Workstation directly behind the display for a compact, efficient, single-footprint solution.
HP Z24i G2 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
25 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Die-cast aluminium base with black pearl paint
53.88 cm x 20.5 cm x 46.3 cm
6.6 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
Plug and Play, BSMI, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, WEEE, ICES, cTUVus, MEPS, E-Standby, KC, ERP, CEL, ISC, RCM, MSIP, SEPA, CoC, low halogen, CU, SmartWay
5-year warranty
Display Type
Energy Class
Class A
36 kWh
25 W
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Pixel Per Inch
94.07
Brightness
300 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, arsenic-free glass
53.88 cm x 20.5 cm x 46.3 cm - with stand
6.6 kg
VGA , HDMI , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
AC 120/230 V
20 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 53.2 cm - depth: 4.68 cm - height: 35.1 cm - weight: 3.7 kg , With stand - width: 53.2 cm - depth: 21.4 cm - height: 50.3 cm - weight: 6.6 kg
Shipping Width
62.5 cm
Shipping Depth
27.3 cm
Shipping Height
42 cm
Shipping Weight
9.3 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
HP Z24i G2 24 Bundle deal on HP Z24i G2 24" 1920x1200 5ms HDMI VGA DisplayPort LED Monitor
£366.47
Diagonal Size: 24in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 150 - 300
