Get outstanding image accuracy, exceptional adjustability, and mission-critical reliability optimized for commercial environments. Built with IPS Gen 2 panels, the HP Z24i 61 cm (24') IPS Display delivers power savings over first-generation IPS technology and extra-wide viewing angles that foster collaboration.
Say hello to your new power-smart IPS Gen 2 team player
Lower your power consumption and get 99% coverage of sRGB color spaces from IPS Gen 2 panels. Speed team reviews and collaborative decision-making with extra-wide viewing angles that give everyone the same great view.See all the stunning details on a 61 cm (24') diagonal display with narrow bezels and 1920 x 1200 resolution, which delivers 120 extra lines of data and 2.3M pixels.Experience crisp, clear presentation from 300 cd/m2 brightness, 1000:1 contrast ratio, 5M:1 dynamic contrast ratio, and 8 ms response time.Enhance the dark regions of your onscreen images and see the smallest details even better with integrated Black Stretch technology. -
Designed-in comfort
Find your most comfortable position with an HP-exclusive 4-way adjustable stand and an integrated HP QR2 Quick Release than enables VESA mounting. -
Easy-access connectivity within arm's reach
Enjoy future-ready and legacy connectivity from a range of inputs that include DisplayPort 1.2, DVI, VGA, and an integrated USB hub. -
Keep it together
Get organized with the integrated cable management clip. Create a clean, compact all-in-one with the optional HP Thin Client Mount Kit. The HP QR2 Quick Release is integrated into the display to enable quick set up, and it's VESA mountable. -
Control your environmental impact
Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that goes beyond IPS Gen 2 technology with ENERGY STAR and EPEAT Gold qualifications.The HP Z24i 61 cm (24') IPS Display also includes mercury-free display backlights, a low halogen design, and arsenic-free display glass. -
Meet your monitor's new best friend
Customize your workspace with resizable screen partitions. Work in documents, spreadsheets, and email in separate regions of the screen-at the same time-with HP Display Assistant software.View open applications on all of your connected displays with the expanded toolbar. Help deter theft with a user-designated PIN that deactivates the monitor if it's disconnected from a PC without approval. -
Breathe easy
Rest assured that your IT investment is supported by a standard, three-year limited warranty. Select optional HP Care Pack Services to extend your protection up to 5 years.
- HP Z24i - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.94 cm x 23.79 cm x 52.5 cm
- 6.96 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, VCCI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CECP, CEL, EPA
- 3-year warranty
- Display Type
- Diagonal Size
- 24"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 24 - 94 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Anti-glare
- Black
- 6.96 kg
- VGA , DVI-D (HDCP) , DisplayPort (HDCP) , USB 2.0 upstream , 4 x USB 2.0 downstream
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 120 mm
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 36 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- Width: 55.94 cm - depth: 6.45 cm - height: 36.5 cm - weight: 4.73 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
