Your basket is empty
HP Z24i 24" 1920x1200 VGA DVI-D DisplayPort IPS Monitor
Quicklinx: 98QHWS00 Mfr#: D7P53AT#ABU
Get outstanding image accuracy, exceptional adjustability, and mission-critical reliability optimized for commercial environments. Built with IPS Gen 2 panels, the HP Z24i 61 cm (24') IPS Display delivers power savings over first-generation IPS technology and extra-wide viewing angles that foster collaboration.
HP Z Display Z24i - LED monitor - 24"
LED-backlit LCD monitor - 24"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
55.94 cm x 23.79 cm x 52.5 cm
6.96 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CECP, CEL, EPA, TCO Displays 6.0
3 years warranty
Display Type
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 94 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Anti-glare
6.96 kg
VGA , DVI-D (HDCP) , DisplayPort (HDCP) , USB 2.0 upstream , 4 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
360
Rotation Angle
90
Height Adjustment
120 mm
36 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
Width: 55.94 cm - depth: 6.45 cm - height: 36.5 cm - weight: 4.73 kg
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
