HP's entry level workstations just got better. The HP Z240 with two amazingly versatile form factors, packs the performance, features, and reliability of a workstation into the price point of a desktop PC.
Choose the OS for you
Support your unique user needs with a choice of Windows 10 Pro or Linux operating systems. -
Better Package. Bigger Punch
Get more performance, expandability and flexibility in the chassis the world loves. -
Powerful performance
Achieve the performance you need with your choice of next generation Intel Xeon processors or Intel Core processors. -
Ultra-fast storage
Handle large files, reduce work time and increase performance with the optional HP Z Turbo Drive. -
Work smarter
Up to 64 GB DDR4 ECC memory helps provide no compromise capacity, performance, and reliability. -
Geared up graphics
Ignite productivity with NVIDIA professional graphics cards in 2D or 3D.
- HP Workstation Z240 - MT - Core i5 6600 3.3 GHz - vPro - 8 GB - HDD 1 TB
- Workstation - mini tower
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- 1 x Intel Core i5 (6th Gen) 6600 / 3.3 GHz (, up to 3.9 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 530 Dynamic Video Memory Technology 5.0
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, PDF Complete Corporate Edition, HP Performance Advisor, HP PC Hardware Diagnostics UEFI, HP Client Security, HP Remote Graphics Software 7.1
- Black
- 17 cm x 44.2 cm x 39.9 cm
- 8.6 kg
- Pricing Type
- Promo
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- Product Form Factor
- Mini tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6600
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel C236
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 2 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 2 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ)
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DVI, DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse
Mouse
- Technology
- Laser
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
- Bays
- 2 (total) / 2 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x internal 2.5" x 1/8H
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x1 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x4 - full-length, full-height , 1 (total) / 1 (free) x M.2 Card (x4 mode)
- 6 x USB 3.0 (2 front, 4 rear) , 4 x USB 2.0 (2 front, 2 rear) , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 2 x DisplayPort , 1 x DVI , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x microphone
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS, WEEE, ACPI 4.0
- Pricing Type
- Promo
- Power supply
- Voltage Required
- Power Provided
- 400 Watt
- Efficiency
- 92%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence - English
- Software
- 17 cm
- 44.2 cm
- 39.9 cm
- 8.6 kg
- 5 °C
- 35 °C
- 8 - 85% (non-condensing)
