Create an immersive, virtually seamless multi-display view with the HP Z23n Narrow Bezel IPS Display, which is practically borderless on three sides. It's also factory calibrated for color accuracy between projects and displays and includes flexible device connectivity.
Continuous, eye-catching imagery
Experience extended views from almost anywhere in the room with a panel that is nearly borderless on three sides and has 178-degree viewing angles from IPS technology. -
Consistent, reliable color accuracy
Deliver optimal color quality across your entire user base with a factory-calibrated 96% sRGB color gamut. -
Failure is not an option
Don't just take our word for it. We back the display up with a three-year limited warranty, optional HP Care Pack, and an HP Pixel Defect Policy that will replace the screen if even one bright subpixel fails.
- HP Z23n - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class A
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 22 W
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 7 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 96% sRGB
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 52.08 cm x 18.9 cm x 48.66 cm
- 5 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, VCCI, BSMI, GS, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, MEPS, China Energy Label Level 1, KC, CECP, CEL, EPA, ISC, SEPA
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 32 kWh
- Diagonal Size
- 23"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Per Inch
- 95.78
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 96% sRGB
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, colour balance, input select
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, Mercury free
- Black
- 52.08 cm x 18.9 cm x 48.66 cm - with stand
- 5 kg
- VGA , HDMI (HDCP) , DisplayPort (HDCP) , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 15 cm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA 100 x 100 mm
- Cables Included
- 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 22 W
- Power Consumption (Typical)
- 15 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Included Software
- HP Display Assistant
- OS Required
- Microsoft Windows 7, Windows 8 / 8.1
- Dimensions & Weight Details
- Without stand - width: 52.08 cm - depth: 5.23 cm - height: 31.2 cm - weight: 3 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
