Get outstanding image accuracy, exceptional adjustability, and mission-critical reliability optimized for commercial environments. Built with IPS Gen 2 panels, the HP Z23i 58,4 cm (23') IPS Display delivers power savings over first-generation IPS technology and extra-wide viewing angles that foster collaboration.
Say hello to your new power-smart IPS Gen 2 team player
Lower your power consumption and get 97% coverage of sRGB color spaces from IPS Gen 2 panels. Speed team reviews and collaborative decision-making with extra-wide viewing angles that give everyone the same great view.View all the stunning details a narrow-bezel 58, 4 cm (23') diagonal display with 1920 x 1080 Full HD resolution. Experience crisp, clear presentation from 250 cd/m2 brightness, 1000:1 contrast ratio, 5M:1 dynamic contrast ratio, and 8 ms response time.Enhance the dark regions of your onscreen images and see the smallest details even better with integrated Black Stretch technology. -
Get comfortable with a TCO Certified Edge monitor
Find your most comfortable position with a 4-way stand that meets the TCO Certified Edge designation for innovative products at the forefront of environmental and ergonomic stand design. -
Easy-access connectivity within arm's reach
Enjoy future-ready and legacy connectivity from a range of inputs that include DisplayPort 1.2, DVI, VGA, and an integrated USB hub. -
Control your environmental impact
Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that goes beyond IPS Gen 2 technology with ENERGY STAR .The HP Z23i 58,4 cm (23') IPS Display also includes mercury-free display backlights, a low halogen design, and arsenic-free display glass. -
Meet your monitor's new best friend
Customize your workspace with resizable screen partitions. Work in documents, spreadsheets, and email in separate regions of the screen-at the same time-with HP Display Assistant software.View open applications on all of your connected displays with the expanded toolbar. Help deter theft with a user-designated PIN that deactivates the monitor if it's disconnected from a PC without approval. -
Breathe easy
Rest assured that your IT investment is supported by a standard, three-year limited warranty. Select optional HP Care Pack Services to extend your protection up to 5 years.
- HP Z23i - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- USB 2.0 hub
- Panel Type
- IPS2
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 86%, 95%, 72% NTSC (CIE 1931)
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54.4 cm x 24.29 cm x 46.99 cm
- 6.4 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Plug and Play, CSA, TUV, VCCI, C-Tick, BSMI, GOST, cUL, GS, NOM, WHQL, CB, PSB, MIC, FCC, S Mark, CEL
- Display Type
- Diagonal Size
- 23"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS2
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 24 - 94 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- Controls & Adjustments
- Brightness, contrast, colour balance, input select
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- Anti-glare
- Black
- 54.4 cm x 24.29 cm x 46.99 cm - with stand
- 6.4 kg
- VGA , DVI-D (HDCP) , DisplayPort (HDCP) , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A)
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 360
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- Cables Included
- 1 x DVI cable , 1 x USB cable , 1 x DisplayPort cable
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 28 Watt
- Power Consumption Sleep
- 0.5 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 54.4 cm - depth: 5.1 cm - height: 32.9 cm - weight: 4.19 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
