HP Z230T Workstation Intel Xeon E3-1246v3
8GB
 256GB SSD Windows 7 Professional 64-bit
HP Z230T Workstation Intel Xeon E3-1246v3 8GB 256GB SSD Windows 7 Professional 64-bit
Quicklinx: B6NWWS00 Mfr#: G1X41EA#ABU
Processor Type: Xeon
Operating System: Microsoft Windows 7 Professional 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
Storage Type: SSD
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
£1,020.00 ex VAT
£1,224.00 inc VAT
Affordable performance and flexibility, re-define. Create a totally immersive work environment for those who demand reliability and performance on a budget. Designed for heavy 24x7x365 workloads, the HP Z230 delivers next-generation processor and graphics technologies in a redesigned, compact yet impressively expandable tower.
  • Rock solid reliability, affordably priced
    Designed for heavy 24x7x365 workloads. The affordable HP Z230 Tower Workstation handles the demanding workloads of business applications.Gain peace of mind from our extreme test and validation processes with workstations designed for always-on environments.Control your environmental impact better than ever while lowering your total cost of ownership with a 92% efficient power supply and enhanced system reliability.Work smarter with your software tools. This HP workstation has earned a wide range of ISV certifications to deliver better, smarter performance.
  • Power for now, room to grow
    Grow along with your business. The HP Z230 Tower Workstation is designed to scale and expand, so you can add more storage and connectivity when you need it.Complete computing power in a new compact design. HP's redesigned and more compact workstation is robust and flexible, while freeing up more space for work.Spend less time waiting. Speed up data transfers with six available drive bays including a 6,3 cm (2.5') HD bay for high speed solid state drives.Boost your storage performance with RAID, solid state drives, or get the best of both worlds by combining large hard drives with an optional solid state drive as a cache device.Optimize this workstation for peak performance. HP Performance Advisor helps you easily configure your system with the best settings designed for specific applications.
  • Totally immersive
    Power to spare-and share. The latest Intel Xeon processors and rich graphics keep up with your work. Plug in and work on up to six displays.Enjoy the latest in performance and energy efficiency from Intel's next generation processor architecture.Keep more work front-and-center with support for up to six monitors. Choose between cost-effective integrated graphics and powerful 2D or 3D discrete graphics choices.Easily connect your peripherals and devices using the four PCIe slots, one PCI input/output slot, ten external USB ports and the fast charging USB port.With HP RGS you can take your graphics intensive workstation applications wherever you go. Collaborate with colleagues around the office or around the world, in real time.
HP Workstation Z230 - MT - Xeon E3-1246V3 3.5 GHz - 8 GB - 256 GB - UK
Workstation - mini tower
Platform Technology
Intel vPro Technology
1 x Intel Xeon E3-1246V3 / 3.5 GHz (3.9 GHz) (Quad-Core)
Processor Socket
LGA1150 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) DDR3 SDRAM - ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 256 GB - SATA 6Gb/s
Optical Storage
DVD SuperMulti
Card Reader
15 in 1
Graphics Controller
Intel HD Graphics P4600 Shared Video Memory (UMA)
Audio Output
Integrated
GigE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Jack black
17 cm x 44.2 cm x 39.9 cm
8.8 kg
Platform Technology
Workstation
Recommended Use
Small business, corporate business
Product Form Factor
Mini tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Jack black
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1150 Socket
Chipset Type
Intel C226
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total) / 2 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
2 x 4 GB
RAM Supported
32 GB unbuffered - ECC , 32 GB unbuffered - non-ECC
Hard Drive
SSD
1 x 256 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1
Optical Storage
DVD SuperMulti - SATA
Card Reader
15 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
DVI, DisplayPort
Max Monitors Supported
3
Audio Output
Integrated
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Localization & Layout
Mouse
Laser
USB
Integrated
Ethernet Controller
Intel I217-LM
Wake on LAN (WoL), PXE support
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x internal 3.5" , 1 (total) / 0 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - full-height (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x16 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x1 - full-height , 1 (total) / 1 (free) x PCI - full-length, full-height
4 x USB 3.0 (2 front, 2 rear) , 6 x USB 2.0 (2 front, 4 rear) , 1 x headphones (1 in front) , 2 x microphone (1 front, 1 rear) , 1 x DVI-I , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out
Power-on password, USB port control, audio ports control, network port control, Setup Password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, ACPI 4.0
Power supply
Nominal Voltage
Power Provided
400 Watt
80 PLUS Certification
80 PLUS Gold
Efficiency
92%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence - English
Software
Windows 7 Professional 64-bit recovery DVD
17 cm
44.2 cm
39.9 cm
8.8 kg
5 °C
35 °C
8 - 85% (non-condensing)
8GB
 256GB SSD Windows 7 Professional 64-bit Bundle deal on HP Z230T Workstation Intel Xeon E3-1246v3 8GB 256GB SSD Windows 7 Professional 64-bit
£1,119.17
Storage Type: SSD
Processor Model: E3-1246V3
Type: Workstation
Case Style: Mini tower
Display: no
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Brand: HP
Price Range Ex VAT: 1000 - 1500
