Affordable performance and flexibility, re-defined. Create a totally immersive work environment for those who demand reliability and performance on a budget. Designed for heavy 24x7x365 workloads, the HP Z230 delivers next-generation processor and graphics technologies in a redesigned, surprisingly capable small form factor.
Rock solid reliability, affordably priced
Designed for heavy 24x7x365 workloads. The affordable HP Z230 Small Form Factor Workstation handles the demanding workloads of business applications.Gain peace of mind from our extreme test and validation processes with workstations designed for always-on environments.Control your environmental impact better than ever while lowering your total cost of ownership with a 92% efficient power supply and enhanced system reliability.Work smarter with your software tools. This HP workstation has earned a wide range of ISV certifications to deliver better, smarter performance. -
The workstation that fits your workspace
Engineered to impress. The redesigned HP Z230 Small Form Factor Workstation provides the capability and flexibility you demand in a 61% smaller form factor than the tower.Maintain impressive performance, greater storage capacity, more input/output ports and greater flexibility while retaining the same small form factor size.Save time with easy data transfers. Accommodate more storage devices with four total drive bays, including a 6,35 cm (2.5') HD bay for high-performance solid state drives.Boost your storage performance with RAID, solid state drives, or get the best of both worlds by combining large hard drives with an optional solid state drive as a cache device.Optimize this workstation for peak performance. HP Performance Advisor helps you easily configure your system with the best settings designed for specific applications. -
Totally immersive. Perfectly productive
Power to spare-and share. The latest Intel Xeon processors and rich graphics keep up with your work. Plug in and work on up to six displays.Enjoy the latest in performance and energy efficiency from Intel's next generation processor architecture.Keep more work front-and-center with support for up to six monitors. Choose between cost-effective integrated graphics and powerful 2D or 3D discrete graphics choices.With HP RGS you can take your graphics intensive workstation applications wherever you go. Collaborate with colleagues around the office or around the world, in real time.
- HP Workstation Z230 - SFF - Xeon E3-1226V3 3.3 GHz - vPro - 8 GB - HDD 1 TB
- Workstation - small form factor - power-on password, serial port I/O control, USB port control, audio ports control, network port control, Setup Password
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- 1 x Intel Xeon E3-1226V3 / 3.3 GHz (, up to 3.7 GHz, (Quad-Core)
- Processor Socket
- LGA1150 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics P4600
- Audio Output
- Integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- Jack black
- 33.7 cm x 38.4 cm x 10 cm
- 7.2 kg
- Pricing Type
- Promo
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Small form factor
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Jack black
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E3-1226V3
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel C226
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total) / 2 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 2 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 5
- RAID Level
- RAID 0, RAID 1
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- DisplayPort
- Max Monitors Supported
- 3
Audio Output
- Integrated
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Technology
- Laser
- Interface
- USB
- Integrated
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- IEEE 802.3ab
- Bays
- 1 (total) / 0 (free) x external 5.25" x 1/2H , 1 external 3.5" , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x4 - low-profile (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x1 - low-profile
- 4 x USB 3.0 (2 front, 2 rear) , 6 x USB 2.0 (2 front, 4 rear) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x serial , 3 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out
- Power-on password, serial port I/O control, USB port control, audio ports control, network port control, Setup Password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS, WEEE, ACPI 4.0
- Pricing Type
- Promo
- Power supply
- Voltage Required
- Power Provided
- 240 Watt
- Efficiency
- 92%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- 33.7 cm
- 38.4 cm
- 10 cm
- 7.2 kg
- 5 °C
- 35 °C
- 8 - 85% (non-condensing)
