Create a captivating view with minimal visual disruptions with the HP Z22n Narrow Bezel IPS Display. Nearly borderless on three sides, it also includes factory color calibration for consistent color between projects and displays and flexible device connectivity.
Impressive continuous imagery
Enable virtually seamless views from almost anywhere in the room with a display that's almost borderless on three sides and has 178-degree viewing angle IPS technology. -
Color accuracy the first time and every time
Maintain visual integrity across all of your displays with a 95% sRGB color gamut that is calibrated at the factory. -
Zero bright sub-pixel defects, guaranteed
Don't just take our word for it. We back the display up with a three-year limited warranty, optional HP Care Pack, and an HP Pixel Defect Policy that will replace the screen if even one bright sub-pixel fails.
- HP Z22n - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class A
- Energy Consumption per Year
- 30 kWh
- Power Consumption (On mode)
- 20 W
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.24795 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 48.81 cm x 18.9 cm x 47.74 cm
- 4.75 kg
- Localisation
- English / United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Plug and Play, UL, TUV GS, VCCI, C-Tick, BSMI, TUV S, WHQL, CB, CCC, TUV Ergo, FCC, KC, CECP, CEL Grade 1, SEPA
- Display Type
- Energy Class
- Class A
- 30 kWh
- Diagonal Size
- 21.5"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.24795 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, 99% sRGB colour gamut
- Black
- 4.75 kg
- HDMI (HDCP) , DisplayPort (HDCP) , VGA (HDCP) , 2 x USB 2.0 downstream , USB 2.0 upstream
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 45
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 20 W
- Power Consumption (Typical)
- 34.7 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 48.81 cm - depth: 18.9 cm - height: 47.74 cm - weight: 4.75 kg , Without stand - width: 48.81 cm - depth: 5.22 cm - height: 29.26 cm - weight: 2.75 kg
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
