Your basket is empty
HP Z22n Narrow Bezel LED 21.5" Monitor1920x1080 7MS Black
Quicklinx: C7XKWS00 Mfr#: M2J71AT#ABU
Create a captivating view with minimal visual disruptions with the HP Z22n Narrow Bezel IPS Display. Nearly borderless on three sides, it also includes factory color calibration for consistent color between projects and displays and flexible device connectivity.
HP Z22n - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
20 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
48.81 cm x 18.9 cm x 47.74 cm
4.75 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Plug and Play, UL, TUV GS, VCCI, C-Tick, BSMI, TUV S, WHQL, CB, CCC, TUV Ergo, FCC, TCO Certified Edge, KC, CECP, CEL Grade 1, SEPA
Display Type
Energy Class
Class A
30 kWh
20 W
Diagonal Size
21.5"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 99% sRGB colour gamut
4.75 kg
HDMI (HDCP) , DisplayPort (HDCP) , VGA (HDCP) , 2 x USB 2.0 downstream , USB 2.0 upstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
45
Height Adjustment
150 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
30,000 hours
34.7 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 48.81 cm - depth: 18.9 cm - height: 47.74 cm - weight: 4.75 kg , Without stand - width: 48.81 cm - depth: 5.22 cm - height: 29.26 cm - weight: 2.75 kg
5 °C
35 °C
20 - 80% (non-condensing)
