HP Z2 G4 MT Intel Xeon W-2102 8GB 1TB HDD Windows 10 Pro
Quicklinx: DQHLWS00 Mfr#: 2WU68ET#ABU
Perfect for engineering, visualization and Machine Learning, HP's most popular workstation delivers disruptive performance for a wide spectrum of applications. With a choice of Intel Xeon or Core X processors, and support for dual extreme graphics, you get all you need, nothing more.
  • Operating Systems
    Support your unique user needs with a choice of Windows 10 Pro for Workstations 64 or Linux operating systems.
  • Professional Performance
    Run demanding professional apps with the newest generation Intel Xeon processors available with up to 18 cores for powerful performance and productivity.
  • Intel Core X-Series processors
    Experience disruptive price-performance on multi-threaded applications, or combined workflows such as simulation based design, with Intel Core X-Series processors: the high-performance single-socket processors from Intel .
  • Graphics
    Get serious about graphics and reach peak productivity with access to a breadth of NVIDIA and AMD professional graphics from entry to high-end 3D.
  • Storage
    Install pro-grade storage hardware and elevate your storage-bound apps without sacrificing standard PCIe slots.
  • Functional Design
    The simply stunning design features front and rear handles, so you can easily relocate your system.
HP Workstation Z4 G4 - MT Xeon W W-2102 2.9 GHz - vPro - 8 GB - HDD 1 TB - UK
Workstation - MT
Platform Technology
Intel vPro Platform
Height (Rack Units)
4U
1 x Intel Xeon W W-2102 / 2.9 GHz (Quad-Core)
Processor Socket
LGA2066 Socket
Processor Main Features
Hyper-Threading Technology
Cache Memory
8.25 MB
Cache Per Processor
8.25 MB
RAM
8 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-20800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
No graphics
1GbE
Keyboard
OS Provided
Windows 10 Pro for Workstations 64-bit Edition
16.9 cm x 44.5 cm x 38.6 cm
11.3 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
TCO Certified Desktops 9, ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
MT - 4U
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Intel Xeon W W-2102
Clock Speed
2.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA2066 Socket
Chipset Type
Intel C422
Cache Memory
Installed Size
8.25 MB
Cache Per Processor
8.25 MB
RAM
Installed Size
DDR4 SDRAM - ECC
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-20800
DIMM 288-pin
Slots
8 (Total) / 7 (empty)
Registered
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), PXE support
Bays
2 (total) / 1 (free) x external 5.25" , 2 (total) / 2 (free) x internal 3.5"
Slots
2 (total) / 2 (free) x PCIe 3.0 x16 , 2 (total) / 2 (free) x PCIe 3.0 x4 , 1 (total) / 1 (free) x PCIe 3.0 x8 , 2 (total) / 1 (free) x M.2 Card
8 x USB 3.1 Gen 1 , 1 x headphones/microphone , 2 x USB 2.0 , 1 x audio line-in , 1 x audio line-out , 2 x USB-C , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, FIPS 140-2, Common Criteria EAL4+, WEEE 2002/96/EC, ISO 11469, ISO 1043
HP Smart Buy
Power supply
Power Provided
750 Watt
80 PLUS Certification
80 PLUS
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro for Workstations 64-bit Edition English
Sustainability Information
TCO Certified
ENERGY STAR Certified
16.9 cm
44.5 cm
38.6 cm
11.3 kg
5 °C
35 °C
10 - 85% (non-condensing)
Warranties (1)
DQHL HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site In Stock £45.90
Other bundles (1)
DQHL HPE USB to Serial Port Adapter In Stock £13.95
